Just playing with the new system patch-rollback command
I'm guessing that in a cluster theres a sequence to do this in ?
I've got a test 2 node cluster that was upgraded from 6.6.8 -> 6.7.0 -> 6.7.1
Now running system patch-rollback on both nodes . Thisi s fine as its a test cluster with no real auths going on, but if I had to revert a production cluster, I guess I'd do the slave publishers 1 at a time first, get them up and running and then to the master publisher. Correct?
This is working on the premius that ewhen upgrading you need to upgrade ther master publisher 1st and then do the slave ones
A
