Clearpass TACACS - Authentication fail
  • 1.  Clearpass TACACS - Authentication fail
    Posted Oct 08, 2014 03:44 PM
    Hi Guys,
    I'm using the CPPM as a TCACS Server, authenticanting some different switches models .
    I'm having a problem specifically with an HP (H3C) switch. When I try to access this switch with username and password that is registered in CPPM internal base, I receive the information from CPPM that the autehntication was accepted, but the switch reject the access.
    I have no problem with the others switches ( Ciscco and Dell).
    Is there something that I need to configure in the CPPM specically for HP (H3C) switches?
    Thanks i advance.
    Leandro Surcin
  • 2.  RE: Clearpass TACACS - Authentication fail
    Posted Oct 08, 2014 03:51 PM
    Youneed to send back a privilege level of 15. Create a new enforcement profile and add it to your policy.
  • 3.  RE: Clearpass TACACS - Authentication fail
    Posted Oct 08, 2014 04:05 PM
    HP ProCurve config:
    aaa authentication login privilege-mode
    aaa authentication ssh login tacacs local
    aaa authentication ssh enable tacacs local
    tacacs-server host 10.100.60.80 key Pr0Curve
    ClearPass:
    Enforcement profile:
    Enforcement policy:
  • 4.  RE: Clearpass TACACS - Authentication fail
    Posted Oct 20, 2014 03:34 PM
    Hi.
    Its an HP 5120 switch model from H3C and I already configured the enforcement profile privilege level 15.
    Do you have some other advice?
    Tks.
  • 5.  RE: Clearpass TACACS - Authentication fail
    Posted Oct 20, 2014 04:28 PM
    Have you set super password?
    [CS01]super password level 3 cipher ?
      STRING<1-53>  Ciphertext password string
    [CS01]super password level 3 cipher yoursecretkey
     then after you authenticate at level 0, type "super" to get to level 3
    <CS01>super
    Please input the password to change the privilege level. Press CTRL_C to abort.
     Password:
    User privilege level is 3, and only those commands can be used
    whose level is equal or less than this.
    Privilege note: 0-VISIT, 1-MONITOR, 2-SYSTEM, 3-MANAGE
  • 6.  RE: Clearpass TACACS - Authentication fail
    Posted Oct 20, 2014 05:34 PM
    Hi.
    Tks.
  • 7.  RE: Clearpass TACACS - Authentication fail
    Posted Feb 12, 2018 06:03 AM
    Did you ever get to the bottom of this?
