ClearPass Time Source - Next Monday
  • 1.  ClearPass Time Source - Next Monday
    Posted Aug 31, 2018 03:54 PM
    I'm looking for assistance with adding a filter to the time source auth source. I'm looking for a filter to return the date of the next Monday.
    If a user connects on a Monday, the time source filter would return the date of the following Monday. If the same user next connects on a Wednesday, the time source filter would still return the date of the following Monday.
    Any help in generating the SQL syntax to place in the filter will be appreciated.
  • 2.  RE: ClearPass Time Source - Next Monday
    Posted Sep 10, 2018 02:01 PM
    If anyone was interested in the solution for their own environment, here's what I received from TAC.
    select date_trunc('day', localtimestamp(0) + interval '1 day' * (select 8 - extract(isodow from date_trunc('hour', localtimestamp(0))) as temp)) as next_monday
  • 3.  RE: ClearPass Time Source - Next Monday
    Posted Dec 29, 2023 08:39 AM
    Thanks for sharing the solution.
    What would I need to change if  i would like to get "Next Friday"?
  • 4.  RE: ClearPass Time Source - Next Monday
    Posted Jan 02, 2024 08:01 AM
    With some help from here, I found the following SQL query that finds the start of the first coming Friday:
    postgres=# select date_trunc('day', localtimestamp(0) + interval '1 day' * ( select ( 12 - extract(isodow from date_trunc('hour', localtimestamp(0)))::int ) % 7 as temp )) as next_friday;
         next_friday
     2024-01-05 00:00:00
    (1 row)
    If you want 18:00h / 6PM:
    postgres=# select date_trunc('day', localtimestamp(0) + interval '1 day' * ( select ( 12 - extract(isodow from date_trunc('hour', localtimestamp(0)))::int ) % 7 as temp )) + interval '18 hour'  as next_friday;
         next_friday
     2024-01-05 18:00:00
    (1 row)
    This is standard Postgres SQL time calculations. Postgres is the database system that ClearPass uses under the hood.
