Clearpass TLS cert machine authentication
  • 1.  Clearpass TLS cert machine authentication
    Posted Oct 31, 2017 04:12 PM
    I am attempting to setup clearpass for onboarding users with certs.  I got it all working but ran into a slight issue I am not sure how to solve.   I have onboard setup to provision the cert to both user and machine.  When the user is logged (as user@domain)  everything works fine.  But when the user logs out the machine sends auth as host/user@domain the authenticatiion fails with an alert of EAP-TLS user unknown.
    So I think my question is how to get cert based machine auth working, if I can.   Can I take the request in the format of host/user@domain and autenticate it based on a cert that was onboarded? The issue sees to be that the host/ is not striped and is being used as the username.  I am not super familar with machine auth and have never done it with onboard and certs.
    Ideally I would like to support both machine and user auth using certs as long as I can do both auths via the onboard cert database.  I assume since I have the machine cert I would not have to use ad in order to do the auth?
  • 2.  RE: Clearpass TLS cert machine authentication
    Posted Oct 31, 2017 04:15 PM
    These are domain joined Windows machines?
  • 3.  RE: Clearpass TLS cert machine authentication
    Posted Oct 31, 2017 04:19 PM
    For this discussion let's say no. For the user side we do authenticate via AD but we do not have the hooks in place to check machine status. I was hoping that since we have the machine cert in clearpass onboard we could avoid having to do the machine lookup in AD.
  • 4.  RE: Clearpass TLS cert machine authentication
    Posted Oct 31, 2017 04:21 PM
    So if they're not, then why are you trying to use machine authentication? Machine auth is a domain join only feature.
    Is the certificate in the user's name or the machine's name?
  • 5.  RE: Clearpass TLS cert machine authentication
    Posted Dec 18, 2018 06:12 PM
    Any resolution on this?  Having the same issue.
    thanks
