ClearPass to Mobility Controller integration issue
  • 1.  ClearPass to Mobility Controller integration issue
    Posted Oct 24, 2019 03:38 AM
    I am configuring Aruba ClearPass for a client. I have joined the ClearPass with AD and the connectivity is successful. And also I connect the ClearPass with the Mobility controller. When i tested the conctivity, it gives me the following error:
  • 2.  RE: ClearPass to Mobility Controller integration issue
    Posted Oct 24, 2019 10:14 AM
    I have fixed the error by adding the authentication method of EAP-PEAP,EAP MSCHAPv2 and PAP. On the access tracker, I noticed the authentication method being usd is PAP. Will this affect me in authenticating 802.1x user?
    And in the access tracker the attaced alert message is displayed:
  • 3.  RE: ClearPass to Mobility Controller integration issue
    Posted Oct 24, 2019 10:41 AM
    Pap is ONLY used for Captive Portal.  For 802.1x, at minimum you would only need the EAP-PEAP authentication method.
  • 4.  RE: ClearPass to Mobility Controller integration issue
    Posted Oct 25, 2019 01:58 AM
    Hi Cjoseph,
    Thank you for your replying on the post!
    Based on the attached error, can you suggest us solutions to  the error in connecting vi EAP-PEAP authentication method?
    Fekadu M
