ClearPass Trial - Intune extension
  • 1.  ClearPass Trial - Intune extension
    Posted Nov 09, 2018 03:45 AM
    Hello all,
    I am installing a PoC for ClearPass 6.7 with a 90-day trial license. I would like to integrate ClearPass with Intune, so I am using the ClearPass and Intune integration Guide v3.0.
    While creating the Instance the status is going to failed with reason:
    Error creating extension instance: Store lookup failed
    Looking at the Instance logging I found the following:
    Client:    10.100.168.133:64198
    App User:  oauth2:Microsoft Intune
    Script:    cpg_background.php
    Function:  CreateInstanceSync
    Arguments: array (
      'result' => array (
        'error' => 1,
        'message' => 'Error creating extension instance: Store lookup failed',
        'status' => 404,
        'store_result' => array (
          'error' => 1,
          'message' => 'Error fetching extension from store',
          'status' => 401,
          'errorUrl' => 'http://localhost:2375/v1.27',
          'errorBody' => NULL,
          'errorCode' => NULL,
          'type' => 'http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html',
          'title' => 'Bad Request',
          'details' => 'Installations require Subscription ID',
      'time_elapsed' => 0.53847098350525,
      'store_id' => 'd8d419a8-6a1a-4d7e-b564-81d11a75105a',
      'state' => 'stopped',
    Do I need a Subscription ID for the Extension usage or any other options to get this done?
  • 2.  RE: ClearPass Trial - Intune extension
    Posted Nov 09, 2018 03:51 AM
    Found the solutions.
    I only activated the Platform license and forgot the active the application licenses. After activating these licenses the instance can be created.
