Clearpass - two AD domains in the same service
  • 1.  Clearpass - two AD domains in the same service
    Posted Feb 04, 2015 03:45 AM
    Hello!
    First time for everything right? I have a SSID that needs to authenticate to two different AD's.
    I have CPPM joined to both AD domains, and have one service with both of these as Auth Source.
    The issue I face is that the same username exists in both AD's and it seems that the auth source ignores the domain I add to the username.
    domain1\username1
    domain2\username1
    If I try domain2\user1 it results in a failed auth from domain1 and deny the user to log in.
    I find this in the access tracker (modified names..)
    rlm_ldap: searching for user domain2\username1 in AD:domain1
    rlm_ldap: found user domain2\username1 in AD:domain1
    rlm_eap_mschapv2: Received MSCHAPv2 Response from client
    rlm_mschap: authenticating user username1, domain domain2
    rlm_mschap: user username1 authentication failed
    rlm_mschap: AD status:Logon failure (0xc000006d)
    rlm_mschap: FAILED: MS-CHAP2-Response is incorrect
     Why would it even look for the user in domain1 when I explicitly prefix the username with domain2? Does this imply some sort of trust between the domains?
    Is there a fail-through mechanism or any other mechanism I should look at to get around this?
    I don't really see another way to solve this so I need some assistance from you guys.
  • 2.  RE: Clearpass - two AD domains in the same service
    Posted Feb 04, 2015 06:53 AM
    How do you have configured as backup AD server or as new authentication source ?
    Please read this:
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/What-is-the-best-way-to-authenticate-users-via-multiple-domains/ta-p/181644
    A couple of things:
    - You could decrease the Server Timeout to a lower value (You may want to verify this with TAC)
    - Another that you might need to is that if theres no trust between the two entities you might want to add the second domain server as Password server
  • 3.  RE: Clearpass - two AD domains in the same service
    Posted Feb 04, 2015 07:27 AM
    Thanks Victor. I'll check out that page.
    While waiting I ended up just creating a second service and added a test for the name of the domain in the radius:ietf:user-name. It gets the job done so I'm happy for now.
