Clearpass Unknown End-Host Devices
  • 1.  Clearpass Unknown End-Host Devices
    Posted Mar 21, 2017 08:21 AM
    I face a problem that clearpass see some smratphones as Non-Smart Devices, and the End-Host Identifier  for them appears: Unkown, so clearpass send them to Onguard role.
    How could i solve the problem as it appears with some smartphone devices?
  • 2.  RE: Clearpass Unknown End-Host Devices
    Posted Mar 21, 2017 09:27 AM
    Do you have DHCP helper addresses on all of your client subnets pointing to ClearPass?
    What NADs are you using?
    For OnGuard, it's recommened to use the profile category Computer.
  • 3.  RE: Clearpass Unknown End-Host Devices
    Posted Mar 22, 2017 10:20 AM
    DHCP Helper is configured for all client subnets as clearpass see other smart devices, its Cisco NADs.
    I think the finger print for this mobile isn't known for Clearpass for the last updated version on our device...
  • 4.  RE: Clearpass Unknown End-Host Devices
    Posted Mar 22, 2017 10:31 AM
    What version of ClearPass are you running ?
  • 5.  RE: Clearpass Unknown End-Host Devices
    Posted Mar 22, 2017 10:46 AM
    6.6.3.89660
  • 6.  RE: Clearpass Unknown End-Host Devices
    Posted Nov 29, 2018 07:35 AM
    Hello,i have similar problem i guess, but i dont even have Unknown status ,its just identifier itself,how can i enable profiling of endpoints,in Endpoint menu theres only one device -CPPM server itself
    thnx.
