ClearPass update problem
  • 1.  ClearPass update problem
    Posted Sep 24, 2013 02:52 AM
    This morning, I have done the ClearPass 6.2.0 Cumulative Patch 1 update but now I have no more access to the GUI and the Guest part and don't know if the update is correctly done. I can still access the CLI, so is there a command to know if the update is done or something to go further ?
    Dimitri
  • 2.  RE: ClearPass update problem
    Posted Sep 24, 2013 02:57 AM
    It does apply a patch to the webserver so first check to see if the services are all running
    service status all
  • 3.  RE: ClearPass update problem
    Posted Sep 24, 2013 03:02 AM
    Thank you.
    Ok so here is the result of the command :
  • 4.  RE: ClearPass update problem
    Posted Sep 24, 2013 03:04 AM
    run
    service restart all
    It should have shown the services status and it looks like yours are down.
  • 5.  RE: ClearPass update problem
    Posted Sep 24, 2013 03:18 AM
    Problem solved after the restart of all services (and the restart of CP because of the update). Thanks for you quick help Troy.
    Dimitri
