Clearpass upgrade 6.2.0 to 6.2.6 ( and 6.5 final)
  • 1.  Clearpass upgrade 6.2.0 to 6.2.6 ( and 6.5 final)
    Posted Nov 21, 2016 12:54 PM
    I have a ClearPass CP-VA-5K with version 6.2.0.54353 installed.
    I will update it soon to 6.5.
    Since this is my first attempt to upgrade ClearPass, I am being careful with this .
    1 step:  update by patching  to 6.2.6 ( downloaded CPPM-x86_64-20140214-clearpass-6.2-updates-6-patch.zip.signed).
    This update is done by importing file to policy manager and run the update.
    This is peaceful and I think i do not loose anything or need to change settings in the VM.
    2 Step: Upgrade from 6.2.6 to 6.5 - This is more tricky. I have downloaded the image CPPM-x86_64-6.5.0.71095-upgrade.signed.bin  and the technotes to 6.5.
    This is similar to doing an update? Does it upgrade and mantain the configuration?
    Main issues for me is that i need to create a new disk doble sized of the original. is the only change needed?
    Regards
  • 2.  RE: Clearpass upgrade 6.2.0 to 6.2.6 ( and 6.5 final)
    Posted Jan 10, 2017 10:48 AM
    Hi All
    We are already in version 6.2.6.
    We need to upgrade now to 6.5 version
    Tech note says we can upgrade directly to 6.5. Required only that SCSI ( 0:1) is 500GB
    I have seen mine and has only 400GB. Do I need to add a SCSI (0:2) with 500GB or can I expand in ESXi VM the 400GB to 500GB.
    IS it possible to upgrade existing 6.2.6 or should i create a new VM with 6.5 and then import licenses, certificates...
    Regards
