ClearPass upgrade 6.9 to 6.10
This thread has been viewed 35 times
  • 1.  ClearPass upgrade 6.9 to 6.10
    Posted Nov 23, 2021 11:13 AM
    Hello everyone,
    I will ask a question that may be dumb but I prefer to ask.
    I need to upgrade two ClearPass server on VM appliance from 6.9 to 6.10. Release note requires 1TB and ClearPass won't boot with less space.
    There is two partition on a ClearPass system.
    My question is this : each partition requires 1TB or ClearPass need 1TB that will be split as two partition of 500GB ?
    Thanks for your help.
    Guillaume Lorre
  • 2.  RE: ClearPass upgrade 6.9 to 6.10
    Posted Nov 23, 2021 12:35 PM
    According to this (VMware)
    https://www.arubanetworks.com/techdocs/ClearPass/6.10/Installation-Guide/Content/InstallationGuide/SystemRequirements/SR-ESXiRequirements.htm
    and depending on the installed Clearpass size/version/model. It requires 2 separate disks (500Gb and 1Tb).
    I would work with TAC to make sure you have the required diskspace
    I recently upgraded a lab clearpass to 6.10 and I don't meet the requirements....
    Pasquale Monardo
  • 3.  RE: ClearPass upgrade 6.9 to 6.10
    Posted Nov 24, 2021 11:24 AM
    Hello
    Thanks PM45.
    It's based on this documentation that my question came. And you have another understanding of this.
    Good things to know you were able to install 6.10 whitout this requirement.
    I'll work with TAC.
    Guillaume Lorre
