last person joined: 9 hours ago
Clearpass upgrade and data migration
  • 1.  Clearpass upgrade and data migration
    Posted Nov 27, 2013 03:14 AM
    Hi all,
    I'm planning to upgrade a CPPM server to version 6.2.3. The release notes (ClearPass_6.2.0_ReleaseNotes.pdf) mentions the following:
    System Monitoring Information is not migrated when upgrading from previous versions of 6.X to 6.2, and
    the system monitoring node table will be empty after the upgrade. Users should manually add these
    values. (#16431)'
    What are the options to restore those values/data?
    Thanks!
    Kind regards,
    Mitchell Pompe
    Attachment(s)
  • 2.  RE: Clearpass upgrade and data migration
    Posted Nov 27, 2013 03:18 AM
    Its just telling you that you will need to re-enter the contact and system information
  • 3.  RE: Clearpass upgrade and data migration
    Posted Nov 27, 2013 03:19 AM
    Oh really, I thought it meant  the data in Monitoring » Live Monitoring » System Monitor.
    Thanks for your quick reply!
    Kind regards,
    Mitchell
