Hi
I can't get 6.3 installed on the proper SCSI0:1 partition, no idea how the install proccess is taking the hard disk and this is the second time 6.3 has been installed on SCSI0:0 so after 1 or 2 days I will have low disk warnings because of the space. Right now my VM Admin has sized the server with the following disks:
SCSI0:0 with 15G
SCSI0:1 with 500G
SCSI0:2 with 250G
SCSI0:3 with 500G
This is really a mess but before I delete partitions I want to have only 0:0 and 0:1. I don't want to re-install the server from scratch as I'm depenign on diferent teams to have it fully operational so I'm trying to get it ready on 6.3 to then join it into my cluster.
[appadmin@eu-cppm1]# system boot-image -l
PolicyManager 6.2.0.54353 on SCSI (0:2)
Aruba ClearPass 6.3.1.62009 [Active] on SCSI (0:0)
Alsom I got the below output from my mem-ino.txt from the log of the server.
Partition labels:
/dev/sda1: LABEL="/boot" UUID="551e82f3-6d7f-496c-a512-1343f428593e" TYPE="ext4"
/dev/sda2: LABEL="/image1-old" UUID="bcbb61c7-28da-4177-84d5-503dbab84c38" TYPE="ext4"
/dev/sda3: UUID="92704078-02ef-42ee-9018-cd69ff879911" TYPE="swap"
/dev/sda5: LABEL="/dummy-second" UUID="cfcdbf4f-03e2-450f-9189-a649d1c076fe" TYPE="ext4"
/dev/sda6: LABEL="/shared" UUID="2fb4bd25-a3e7-4cbe-ad5b-41b7ebc1168a" TYPE="ext4"
/dev/sdc1: LABEL="/image2-old" UUID="7172f79d-7a25-48da-aa41-f7fc65e8ed4d" TYPE="ext3" SEC_TYPE="ext2"
/dev/sdb1: LABEL="/image1" UUID="2c19d021-93ef-47bf-84f4-33cffd1bb3a2" TYPE="ext4"
/dev/sdb2: LABEL="/image2" UUID="fe34b1f2-663d-4b9a-a041-eac6976e6d10" TYPE="ext4"
Thank yo very much in advance for your support.
