Clearpass upgrade from 6.6.10 to 6.8
  • 1.  Clearpass upgrade from 6.6.10 to 6.8
    Posted Jun 28, 2019 09:15 AM
    I'm planning to upgrade our Clearpass appliances from 6.6.10 to 6.8.
    Just wondering if anyone has done the upgrade already and ran into any issues?
    Gerard
  • 2.  RE: Clearpass upgrade from 6.6.10 to 6.8
    Posted Jun 28, 2019 09:24 AM
    The most common issue I see is when the MAC address of the first virtual adapter is higher than the second.
    You'll have to do a network rescan. Check the release notes, its been well documented.
    The other is with the licenses, you're going to have to get them moved over to the new format.
  • 3.  RE: Clearpass upgrade from 6.6.10 to 6.8
    Posted Jun 28, 2019 01:29 PM
    Hi Gerard,
    This link has all the information you need for the upgrade to 6.8.x
    https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.8.0/Default.htm#UpgradeUpdate/UpgradingTo_6.8.htm
