ClearPass: Upgrade VMware tools
  • 1.  ClearPass: Upgrade VMware tools
    MVP GURU
    Posted Oct 29, 2015 06:23 AM
    Upgrade VMware tools is supported or not ?
    Because from last release note (6.5.4) :
    For Known issue 30902 : the solution is :
    VMware tools version 9.10.0 that ships with ClearPass 6.5.4 is incompatible with ESXi 5.5.
    Workaround: Restart the ClearPass virtual machine to recover from this state. To enable snapshot
    functionality, install a compatible version of VMware tools from the vSphere client. In the vSphere
    client, right-click on ClearPass VM, select Guest > Install/Upgrade VMware Tools, and then choose
    the Automatic Tools Upgrade option. This will install VMware tools version 9.4.10, which enables
    snapshot functionality.
  • 2.  RE: ClearPass: Upgrade VMware tools
    Posted Oct 29, 2015 06:27 AM
  • 3.  RE: ClearPass: Upgrade VMware tools
    MVP GURU
    Posted Oct 29, 2015 06:45 AM
    Yes and... ?
  • 4.  RE: ClearPass: Upgrade VMware tools
    Posted Oct 29, 2015 07:38 AM
    misread your post
  • 5.  RE: ClearPass: Upgrade VMware tools
    MVP GURU
    Posted Nov 09, 2015 04:17 AM
    Any news ?
  • 6.  RE: ClearPass: Upgrade VMware tools
    Posted Nov 09, 2015 06:49 AM
    Please contact TAC.
  • 7.  RE: ClearPass: Upgrade VMware tools
    MVP GURU
    Posted Apr 27, 2016 07:31 AM
    For information, the upgrade of VM tools is now supported by (Aruba) ClearPass
    From ClearPass Installation Guide :
    Manually Upgrading an ESXi Installation
    This section describes how to perform a manual upgrade of a VMware ESXi virtual machine. This procedure is recommended only if you experience problems when taking snapshots of a virtual machine on an ESXi version 5.x or 6.x.
    By default, ClearPass 6.6 comes with VMware Tools version 9.4.10.37835 installed in it. If you are going to perform a manual VMware Tools upgrade, you must first verify that a version of ClearPass is already installed.
