ClearPass User Authentication Timeouts
  • 1.  ClearPass User Authentication Timeouts
    Posted Jun 04, 2019 03:10 AM
    I am having some issues with a device having timeouts. When I check the access tracker I see the following message:
    -Authentication Method: EAP.
    When the devices can access to the network the message is different:
    -Authentication Method: EAP-PEAP.
    It doesn't specify a specific EAP method when the user is trying to authenticate itself. I an quite new working with Clearpass and authentication methods. Could it be that the end device is authenticating incorrectly? or is it a Clearpass issue?
    Thank you.
    Regards.
  • 2.  RE: ClearPass User Authentication Timeouts
    Posted Jun 04, 2019 03:54 AM
    Typically when you see a time out, it is from the client not finishing the auth request. I could be multiple issues. Most common is issues with the NAD device (switch/Wireless).
    You could have latency issues/route issues, ect. Depending on the device you should be able to look at the clients logs and see where it is giving up.
    I have also seen this issue when its mobile devices. Maily phones. The user will grab the phone and look at the time but will put it away before the client finishes the auth.
    You can also enable debug on CPPM to get a more detail view and export the logs to see the full auth request, but again if there was an error with cppm then you would see a fail or vailed auth. Not a timeout.
