ClearPass Vlan assignment
This thread has been viewed 21 times
  • 1.  ClearPass Vlan assignment
    Posted Jan 22, 2015 08:42 AM
    Evaluating Aruba ClearPass as possible replacement for Cisco Access Control Server. We use Cisco WLAN controllers and access points.
    Wlan SSID set WPA2/Enterprise /AES with MAC auth WLAN.
    Many devices are not AD integrated.
    I need to dynamically map those devices to specific vlans based on MAC address.
    I'd like to create logical device groups, example a group named BP-Mon, and add the mac address of each BP device to that group. Clearpass would then assign all devices in the BP-Mon group to a specific vlan.
    Vlans exist on the connecting Cisco LAN switches and WLAN controllers and tested.
    I can authenticate through ClearPass successfully with all devices but unable to assign vlans dynamically.
    Is this possible? If so, please provide instructions.
    Lenny
  • 2.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 09:25 AM
    Once you identify those devices based the mac address then you need to create a condition in your policy that if the mac belongs to this group of mac address send the VLAN assignment to the switch or controller.
    Make sure those VLANs are define on those devices.
    How do you have you interfaces configured on switches?
    How do you have the WLAN profile configured on the WLC ?
  • 3.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 09:39 AM
    Thanks for the quick reply Victor.
    I would export the MAC addressess directly from Cisco ACS.
    Would you have a step by step guide for?
    1. Create a Group Called BP-Mon
    2. Import the exported MAC address.
    3. Create a Policy with condition that specifies devices in BP-Mon get set to vlan 249.
    Wlan Config.
    WLAN Identifier.................................. 29
    Profile Name..................................... ClearPassTesting
    Network Name (SSID).............................. BHClrPST
    Status........................................... Enabled
    MAC Filtering.................................... Enabled
    Broadcast SSID................................... Disabled
    AAA Policy Override.............................. Enabled
    Network Admission Control
      Radius-NAC State............................... Disabled
      SNMP-NAC State................................. Disabled
      Quarantine VLAN................................ 0
    Maximum number of Associated Clients............. 0
    Number of Active Clients......................... 1
    Exclusionlist.................................... Disabled
    Session Timeout.................................. Infinity
    CHD per WLAN..................................... Disabled
    Webauth DHCP exclusion........................... Disabled
    Interface........................................ entre-wlan-data
    Multicast Interface.............................. Not Configured
    WLAN ACL......................................... unconfigured
    DHCP Server...................................... Default
    DHCP Address Assignment Required................. Disabled
    Static IP client tunneling....................... Disabled
    Quality of Service............................... Bronze (background)
    Scan Defer Priority.............................. 4,5,6
    Scan Defer Time.................................. 100 milliseconds
    WMM.............................................. Allowed
    WMM UAPSD Compliant Client Support............... Disabled
    Media Stream Multicast-direct.................... Disabled
    CCX - AironetIe Support.......................... Enabled
    CCX - Gratuitous ProbeResponse (GPR)............. Disabled
    CCX - Diagnostics Channel Capability............. Disabled
    Dot11-Phone Mode (7920).......................... Disabled
    Wired Protocol................................... None
    IPv6 Support..................................... Disabled
    Peer-to-Peer Blocking Action..................... Disabled
    Radio Policy..................................... 802.11a only
    DTIM period for 802.11a radio.................... 1
    DTIM period for 802.11b radio.................... 1
    Radius Servers
       Authentication................................ 10.26.50.70 1812 = IP address ClearPass
       Dynamic Interface............................. Disabled
    Local EAP Authentication......................... Disabled
       802.11 Authentication:........................ Open System
       Static WEP Keys............................... Disabled
       802.1X........................................ Disabled
       Wi-Fi Protected Access (WPA/WPA2)............. Enabled
          WPA (SSN IE)............................... Disabled
          WPA2 (RSN IE).............................. Enabled
             TKIP Cipher............................. Disabled
             AES Cipher.............................. Enabled
    Auth Key Management
             802.1x.................................. Enabled
             PSK..................................... Disabled
             CCKM.................................... Disabled
             FT(802.11r)............................. Disabled
             FT-PSK(802.11r)......................... Disabled
    FT Reassociation Timeout......................... 20
    FT Over-The-Air mode............................. Enabled
    FT Over-The-Ds mode.............................. Enabled
    CCKM tsf Tolerance............................... 1000
       CKIP ......................................... Disabled
       IP Security................................... Disabled
       IP Security Passthru.......................... Disabled
       Web Based Authentication...................... Disabled
       Web-Passthrough............................... Disabled
       Conditional Web Redirect...................... Disabled
       Splash-Page Web Redirect...................... Disabled
       Auto Anchor................................... Disabled
       H-REAP Local Switching........................ Disabled
       H-REAP Local Authentication................... Disabled
       H-REAP Learn IP Address....................... Enabled
       Client MFP.................................... Optional
       Tkip MIC Countermeasure Hold-down Timer....... 60
    Call Snooping.................................... Disabled
    Roamed Call Re-Anchor Policy..................... Disabled
    SIP CAC Fail Send-486-Busy Policy................ Enabled
    SIP CAC Fail Send Dis-Association Policy......... Disabled
    Band Select...................................... Disabled
    Load Balancing................................... Disabled
  • 4.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 09:46 AM
    Instead of building static host lists, it may be easier for you to create a custom attribute in the ClearPass endpoint database and import all of your devices from ACS with an applicable value.
  • 5.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 09:58 AM
    Good suggestion. Sadly I don't know how to accomplish that yet. All in good time.
  • 6.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 10:23 AM
    Are you working with an Aruba or partner SE on your evaluation?
  • 7.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 11:03 AM
    Yes. They completed inital VM install and base configurtion.
  • 8.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 10:26 AM
    Your profile you should look something like this:
    STL database:
    Enforcement Policy:
  • 9.  RE: ClearPass Vlan assignment
    Posted Jan 22, 2015 11:05 AM
    Thank you. I'll give this a try
