Clearpass VM IP issue
  • 1.  Clearpass VM IP issue
    Posted Jun 12, 2018 12:15 AM
    Running Clearpass 6.7.3
    VM is running on Hyper-V 2012.
    Issue is after i configure the ip and the machine reboots it looses the ip config.
    i have 2 nics one is disabled.
    Any thoughts?
  • 2.  RE: Clearpass VM IP issue
    Posted Jun 12, 2018 12:42 AM
    Can you have both the NIC's enabled, Just to ensure that we are configuring the IP on the right NIC.
  • 3.  RE: Clearpass VM IP issue
    Posted Jun 12, 2018 12:50 AM
    i have just changed the NIC setting and still the same issue
  • 4.  RE: Clearpass VM IP issue
    Posted Jun 12, 2018 12:58 AM
    Just referring to "Installing or Upgrading to 6.7 on a Virtual Appliance" technote.
    Supported Hyper-V Versions
    The following Microsoft Hyper-V versions are supported:
    Microsoft Hyper-V Server 2012 R2
    Microsoft Hyper-V Server 2016
    Windows Server 2012 R2 with Hyper-V
    Windows Server 2016 with Hyper-V
    Ensure that you bring up fresh ClearPass 6.7.0 installs with the network adapter type "Network adapter" instead of
    the legacy option.
  • 5.  RE: Clearpass VM IP issue
    Posted Jun 12, 2018 01:44 AM
    i have both NIC as network adapter.
    its a fresh built box we did not upgrade it.
    Server 2012R2 standard
  • 6.  RE: Clearpass VM IP issue
    Posted Jun 12, 2018 05:25 PM
    Can you check if the have a static MAC address assigned to the VM? Hyper-V will do a dynamic MAC address by default sometimes. Changing the mac address on a linux based VM might cause issues.
  • 7.  RE: Clearpass VM IP issue
    Posted Jun 12, 2018 07:06 PM
    it has dynamic mac address .
    do you want me to change it to static?
  • 8.  RE: Clearpass VM IP issue
    Posted Jun 12, 2018 07:57 PM
    Yes and then check again if IP address is being removed.
  • 9.  RE: Clearpass VM IP issue
    Posted Sep 04, 2019 07:54 AM
    Hi there!
    The same thing happened to me and searching the forums I found this solution.
    https://community.arubanetworks.com/t5/Security/ClearPass-Hyper-v-loses-mgmt-IP-after-reboot/td-p/488584
    After assigning the MAC statically on the HiperV, simply enter CLI and write (system refresh-network)
    which requires reboot. Apparently the command remaps ethernet ports with the new MAC addresses
    Luck!
