Clearpass w/ Juniper for dot1x
  • 1.  Clearpass w/ Juniper for dot1x
    Posted Sep 15, 2020 01:59 AM
    Hi There,
    I'm trying to get 802.1x mac-radius working with Clearpass & a Juniper EX2200 switch and am not seeing any requests hit the Clearpass monitor logs.
    I've followed this guide https://www.juniper.net/documentation/en_US/release-independent/nce/topics/example/nce157-example-aruba-dot1x-mac.html
    I've attached the log output & config of the switch.
    Thanks in advance.
    Attachment(s)
    txt
    dot1x_test_switch.txt   10 KB 1 version
    txt
    JunOS_Dot1x_Log.txt   13 KB 1 version
  • 2.  RE: Clearpass w/ Juniper for dot1x
    Posted Sep 15, 2020 06:44 PM
    Two suggestions, check in the event-viewer.... this scenario is typically because the NAD is not defined on CPPM either as a host/range/subnet.
    IF a dot1X authN is hitting CPPM and the above is true then it will as you correctly point out NOT show in AT but should show in the event-viewer.
  • 3.  RE: Clearpass w/ Juniper for dot1x
    Posted Sep 17, 2020 03:16 AM
    Hi Danny,
    Thanks for the reply.
    That's the strange bit, I don't get any errors in the event viewer & the device is configured using its host IP.
    I've setup a new "device" for the entire subnet and I still don't get a hit in the activity logs.
    Any further suggestions?
  • 4.  RE: Clearpass w/ Juniper for dot1x
    Posted Sep 17, 2020 07:59 AM
    What is the radius source IP configured on the switch ?
    This is the command:
    set access radius-server [CLEARPASS-SERVER-IP] source-address [SWITCH-IP]
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 5.  RE: Clearpass w/ Juniper for dot1x
    Posted Sep 17, 2020 07:12 PM
    Hi Victor,
    Thanks for the reply!
    access {
    radius-server {
    192.168.2.95 {
    port 3799;
    secret "$9$s22gJUjqTF/wYgJ"; ## SECRET-DATA
    source-address 192.168.1.8;
    profile Aruba-Test-Profile {
    authentication-order radius;
    radius {
    authentication-server 192.168.2.95;
    options {
    nas-identifier 192.168.2.95;
    accounting {
    order radius;
