Clearpass web GUI not showing.
This thread has been viewed 23 times
  • 1.  Clearpass web GUI not showing.
    Posted Mar 11, 2016 07:00 PM
    I am setting up 2 clearpass hardware 1 as publisher and 1 as subscriber. I have been following this guide and I am now in page 23. The problem is, I cannot open the the web UI even after things have been setup.
    I did add licenses and  the clustering using the CLI but still the Web UI wont open. I check the time of both server and they seem to have sync with the NTP. Firewalls should all be ok as far as I know.
  • 2.  RE: Clearpass web GUI not showing.
    Posted Mar 11, 2016 08:55 PM
    It would be hard to guess what is wrong from here. Hopefully you opened a case so they can troubleshoot.
  • 3.  RE: Clearpass web GUI not showing.
    Posted Mar 11, 2016 09:51 PM
    Try to telnet to the server over port 80 and 443 to see if it's listening on the ports. Do a "service status all" in cli and confirm the admin-whateveritscalled process is running. Try restating that. Check firewalls in between. Open a case.
  • 4.  RE: Clearpass web GUI not showing.
    Posted Mar 14, 2016 11:58 AM
    Hi Ryan,
    I checked the ports and 80 and 443 seem to be open.
    Here's the ouput of the command.
    [appadmin@clearpass01.nms.xxx.net]# service status all
    Policy server [ cpass-policy-server ] is running
    TACACS server [ cpass-tacacs-server ] is running
    Radius server [ cpass-radius-server ] is running
    Async DB write service [ cpass-dbwrite-server ] is running
    DB replication service [ cpass-repl-server ] is running
    DB change notification server [ cpass-dbcn-server ] is running
    System monitor service [ cpass-sysmon-server ] is running
    System auxiliary service [ cpass-system-auxiliary-server ] is running
    Admin server [ cpass-admin-server ] is running
    Async netd service [ cpass-async-netd ] is running
    Multi-master cache [ cpass-multi-master-cache-server ] is running
    AirGroup notification service [ airgroup-notify ] is running
    Micros Fidelio FIAS [ fias_server ] is running
    ClearPass Virtual IP service [ cpass-vip-service ] is stopped
  • 5.  RE: Clearpass web GUI not showing.
    Posted Mar 14, 2016 12:20 PM
    Are you able to SSH into the Box ?
    Have you tried restarting the Box ?
  • 6.  RE: Clearpass web GUI not showing.
    Posted Mar 14, 2016 12:45 PM
    Yes, I can SSH on the box. Port 22, 80 and 443 are open. I have also restarted them several times.
    We have 2 of these CP-HW-25K sitting in the corner for 2 years and only now that we installed these. So there's really no configuration on them . They still have this old version.
    [appadmin@clearpass01.nms.xxx.net]# show version
    Policy Manager software version : 6.2.2.56893
    Policy Manager model number     : CP-HW-25K
    I was a able to configure one as publisher and one as subscriber using CLI since I can't go to GUI.
  • 7.  RE: Clearpass web GUI not showing.
    Posted Mar 15, 2016 02:28 PM
    The problem was me all this time.
    I was entering the wrong IP on my webrowser.
