ClearPass /.well-know URL fails, is my cluster broken
  • 1.  ClearPass /.well-know URL fails, is my cluster broken
    Posted May 31, 2022 03:51 AM
    I'm build out DUR roles on CX and CPPM and when I try to extract the well-know URL I get 404 error
    (http://<clearpass- fqdn>/.well-known/aruba/clearpass/https-root.pem)
    What am I missing
    ClearPass Pub&Sub has a public cert, with the FQDN in the SAN name,
    ClearPass Version is 6.10
    Do I need to raise a TAC case?
    Andrew Partridge
  • 2.  RE: ClearPass /.well-know URL fails, is my cluster broken
    Posted May 31, 2022 11:35 AM
    Could it be that you are on 6.10.0? Please upgrade to the latest 6.10 patch release as in the early versions that well-known URL worked only with ECC certificates, and the RSA certificate was available as https-root-rsa.pem. Later updates have fixed that in a way that if there is no ECC cert, that the RSA certificate is available on that URL.
    Adding -rsa in the URL would work as well, but there are some security fixes in the latest ClearPass version which should be a reason to upgrade anyway.
  • 3.  RE: ClearPass /.well-know URL fails, is my cluster broken
    Posted Jun 23, 2022 05:39 AM
    I was able to access the cert in Explorer in the end, and firefox.
    I am 6.10.5.185484 although I assume a browser issue and not a clearpass issue
