ClearPass Winbind Reply Failed
  • 1.  ClearPass Winbind Reply Failed
    MVP
    Posted Jun 11, 2018 01:56 PM
    Hey all,
    I am trying to join a new ClearPass server to the domain, but am having strange issue. During join process, I received the following warning:
    But it appears to have joined successfully.
    I then attempted an authentication with a domain-joined windows PC, and it was REJECTED. The Alert tab shows:
    Looking into the logs of this error shows the following:
    Not sure what the issue could be, never ran into this same problem when joining to a domain. I verified the clearpass server object existed in AD and it was a member of the default computer OU, which is where another CPPM server also exists and is working without issue.
    Any ideas would be greatly appreciated.
  • 2.  RE: ClearPass Winbind Reply Failed
    Posted Jun 11, 2018 02:10 PM
    What version are you running on that ClearPass
    Sent from Mail for Windows 10
  • 3.  RE: ClearPass Winbind Reply Failed
    MVP
    Posted Jun 11, 2018 02:18 PM
    6.7.3
  • 4.  RE: ClearPass Winbind Reply Failed
    MVP
    Posted Jun 19, 2018 02:40 PM
    It appears there is some issue translating the clients domain name and the domain appended to the machine authentications - anyone ever run into that?
    Customer domain is ABC123, but devices joined to the domain use device1.123abc.com for example.
    Seems like it can't translate between them.
  • 5.  RE: ClearPass Winbind Reply Failed
    MVP
    Posted Jun 20, 2018 04:54 PM
    Opened a TAC case and we worked with the domain admin and found that the smb_<client domain>.conf file was missing a few lines compared to a working server in the environment.
    The primary line missing is the following:
    After matching up the files, we were able to test a successful domain machine authentication. We also restarted the domain service prior to testing. The other lines missing were under a Logging section, but not sure they played any role in the issue.
    TAC indicated it may be a bug in the code upgrade to 6.7.3 and collected log files and config backup to try and review.
