ClearPass Wired Guest Not Redirecting to Splash page
This thread has been viewed 45 times
  • 1.  ClearPass Wired Guest Not Redirecting to Splash page
    Posted 19 days ago
    Has anyone ever setup a wired guest page just using a EULA and not a self registration? I'm having an issue where while I don't receive any errors from ClearPass or from the logs in the Aruba switch I don't get redirected to the Splash page. I get an Valid IP address, DNS, Gateway, an accept in access tracker for the enforcement and I can see the switch downloaded the user role from a "show port-access client", but it just doesn't redirect me to the splash page.
  • 2.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 19 days ago
    is this for a CX switch or AOS-S? which model number?
  • 3.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 18 days ago
    It's AOS-S
    Aruba JL076A 3810M-40G-8SR-PoE+-1-slot Switch
    Software revision KB.16.11.0008
  • 4.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 18 days ago
    Hi, if you type the captive portal address directly in the client browser can you open it?  May be there is an ACL blocking that access.
    I hope this helps
  • 5.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 18 days ago
    Yes, if I type it into the browser it opens which is why I'm confused it's seems like everything is correct, but just the redirect isn't happening which of  course breaks it. I haven't configured the guest auth portion yet I don't think that should matter, but just in case I want to let it be known.
  • 6.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 18 days ago
    please paste the output of "show port-access client detail"
    or paste the details of DUR enforcement profile.
  • 7.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 18 days ago
    class ipv4 DNS
    match udp any any eq 53
    match tcp any any eq 53
    exit
    class ipv4 DHCP
    match udp any any eq 67
    exit
    class ipv4 Web-Traffic
    match tcp any any eq 80
    match tcp any any eq 443
    exit
    aaa authentication captive-portal profile use-radius-vsa url https://guest.client.com/guest/wired-guest.php
    class ipv4 ClearPass-Web
    match tcp any host ClearPass IP1 eq 80
    match tcp any host ClearPass IP1 443
    match tcp any host ClearPass IP2 eq 80
    match tcp any host ClearPass IP2 eq 443
    match tcp any host ClearPass IP VIP eq 80
    match tcp any host ClearPass IP VIP eq 443
    exit
    policy user ClearPass-Redirect
    class ipv4 DNS action permit
    class ipv4 DHCP action permit
    class ipv4 ClearPass-Web action permit
    class ipv4 Web-Traffic action redirect captive-portal
    exit
    aaa authorization user-role name Guest
    policy ClearPass-Redirect
    captive-portal-profile use-radius-vsa
    vlan-id 222
    exit
  • 8.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 18 days ago
    I think you should add https:// in front of your redirection URL.
  • 9.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 18 days ago
    Sorry just wanting to verify are you saying you believe I should REMOVE the https:// from in front of my redirection URL or I should put it in front of the URL because in the post I made it shows with https:// in front of the URL.
  • 10.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 17 days ago
    Hi, looks fine like this:  aaa authentication captive-portal profile use-radius-vsa url https://guest.client.com/guest/wired-guest.php
    but put it in quotes to see if it makes any difference: "https://guest.client.com/guest/wired-guest.php"
    I hope this helps
  • 11.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 14 days ago
    please paste the output of "show port-access client detail" when the client is connected (and captive portal should be shown) to see what is actually applied to the port.
    Do you have an IP on the switch interface vlan 222? If not, can you try to add that?
  • 12.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 12 days ago
    Hello Herman,
    I've added the port-access command and some new information below:
    After adding the IP address on Vlan 222 I started getting a new error message BUT it would attempt to redirect error message is below the port-access output.
    Show port-access client detail
    Downloaded user roles are preceded by *
     User Role Information
       Type                              : downloaded
       Reauthentication Period (seconds) : 0
       Cached Reauth Period (seconds)    : 0
       Logoff Period (seconds)           : 300
       Untagged VLAN                     : 222
       Tagged VLANs                      :
       Captive Portal Profile            : use-radius-vsa_AOS_DUR_Client_Guest-3034-24
         URL                             : https://guest.client/guest/wired-guest.php
       Policy                            : ClearPass-Redirect_AOS_DUR_Client_Guest-3034-24
    Statements for policy "ClearPass-Redirect_AOS_DUR_Client_Guest-3034-24"
    policy user "ClearPass-Redirect_AOS_DUR_Client_Guest-3034-24"
         10 class ipv4 "DNS_AOS_DUR_Client_Guest-3034-24" action permit
         20 class ipv4 "DHCP_AOS_DUR_Client_Guest-3034-24" action permit
         30 class ipv4 "ClearPass-Web_AOS_DUR_Client_Guest-3034-24" action permit
         40 class ipv4 "Web-Traffic_AOS_DUR_Client_Guest-3034-24" action redirect captive-portal
       exit
    Statements for class IPv4 "DNS_AOS_DUR_Client_Guest-3034-24"
         10 match udp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 53
         20 match tcp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 53
       exit
    Statements for class IPv4 "DHCP_AOS_DUR_Client_Guest-3034-24"
         10 match udp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 67
       exit
    Statements for class IPv4 "ClearPass-Web_AOS_DUR_Client_Guest-3034-24"
         10 match tcp 0.0.0.0 255.255.255.255 10.24.x.x  (Publisher) 0.0.0.0 eq 80
         20 match tcp 0.0.0.0 255.255.255.255 10.24.x.x (Publisher) 0.0.0.0 eq 443
         30 match tcp 0.0.0.0 255.255.255.255 10.24.x.x (Subscriber) 0.0.0.0 eq 80
         40 match tcp 0.0.0.0 255.255.255.255 10.24.x.x (Subscriber) 0.0.0.0 eq 443
         50 match tcp 0.0.0.0 255.255.255.255 10.24.x.x (VIP) 0.0.0.0 eq 80
         60 match tcp 0.0.0.0 255.255.255.255 10.24.x.x (VIP) 0.0.0.0 eq 443
       exit
    --------------------------------------------------------------------------ERROR MESSAGE--------------------------------------------------------------------------------------------------------
    0030:00:57:35.18 DFP mdevMntr:DFP: parsed the HTTP User Agent 3
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:ERR_SSL_BAD_ID
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:SSL_closeConnection() returns status =
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:0
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:SSL_closeConnection() from AppType:
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:1
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:ERR_SSL_NO_CIPHER_MATCH
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:SSL_negotiateConnection() returns
       status =
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:SSL:doProtocol() returns status =
    -- MORE --, next page: Space, next line: Enter, quit: Control-C0030:00:57:35.16 SSL  tCaptivePortalHttpd:SSL_SOCK_receive() returns status =
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:SSL_SOCK_serverHandshake() returns
       status =
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:.
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:Resume state =
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:sslHelloStateMachine() returns status
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:processClientHello3() returns status =
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:00000000
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:Incompatible EC curves returned by
       SSL_setServerCert:
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:14
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:c0
    0030:00:57:35.16 SSL  tCaptivePortalHttpd:SSLSOCK_selectCipherSuiteV3:
       CipherSuite selected = 0x
  • 13.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 7 days ago
    I don't see any class for Web-Traffic_AOS_DUR_Client_Guest-3034-24. And if it's not there, there will be no redirect. It probably should be something like: 10 match tcp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 80
    If this does not solve the issue, it may be better to open a support ticket to have a look at the error messages. Those suggest there is a problem with a certificate, where I think it may have to do with a ECC or RSA certificate mismatch but not fully sure where.
  • 14.  RE: ClearPass Wired Guest Not Redirecting to Splash page
    Posted 3 days ago
    It's a good point that ECC will be defaulted in the newer versions of clearpass so if you're using RSA, you should disable the ECC HTTPS certificate
