Clearpass with 7.4
  • 1.  Clearpass with 7.4
    Posted Dec 19, 2013 08:35 PM
    Hi guys, I just upgraded my WLC to 7.4 and now im having issues with URL- Redirect .... I haven't changed anything but upgraded my controller, now whenever i connect to the SSID it is allowing me straight to the internet?? If i look in clearpsas i see that it is getitng the correct enforcement profile that should be sending back the URL-Direct any other things i should try? FYI, this is for onboard not guest.. and i have the controller set for  Conditional Web Redirect..
    [Mod note: edited subject line for clarity]
  • 2.  RE: Clearpass with 7.4
    Posted Dec 20, 2013 08:05 AM
    Can you take a look at the logs within Cisco?
  • 3.  RE: Clearpass with 7.4
    Posted Dec 20, 2013 11:16 AM
    I believe that there are some ACL changes between different code versions of the WLC so you might have to go in and recreate them in the controller.
  • 4.  RE: Clearpass with 7.4
    Posted Dec 20, 2013 11:46 AM
    thanks for the quick response guys, Actually after upgrading i was looking at my WLAN and "Allow AAA override" was now unchecked.
    This seemed to do the trick if anyone comes accross this same issue.
