Clearpass with AD using Cert
  • 1.  Clearpass with AD using Cert
    Posted Jun 13, 2018 02:54 PM
    Good day Team!
    I am kind of new with the clearpass and AD. I have a question.
    I have been trying to authenticate a user with an AD using certificates but I keep getting a message that the user is not found in the AD.
    I have been changing the CN and the OU to try to catch a match betwwen my machine and Active directory using Clearpass. I believe that the configuration on the Clearpass is wrong.
    I want to ask you guys a couple of questions.
    I attached the configuration of the clearpass and the attributes as well. I want to know if that base DN is the directory that is going to be used on on the AD to look for the customer. And on the second picture, I wanna ask if that is set by default or manually?
    One more question: How do I specify an "any" expresion on the OU field. I want it to know that it has to look in all OUs configured on the AD. The expresion that comes to my mind is "*"
    Thanks !
  • 2.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 03:16 PM
    What is the format of the username shown in access tracker? (Authentication:Full-Username)
  • 3.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 03:53 PM
    Thank you for your reply!
    here is the username: UNAD\aron.gutierrez
  • 4.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 03:55 PM
    Do you have username stripping enabled in your service? This is required for legacy down level logon name username formats.
  • 5.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 04:38 PM
    Hello!
    No, its not enabled. I am looking into this right now.
  • 6.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 04:44 PM
    I enabled the feature but it keep saying that the full username is UNAD\aron.gutierrez.
  • 7.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 04:45 PM
    Is it still failing?
  • 8.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 04:48 PM
    Yes Sir, it is still failing
  • 9.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 04:51 PM
    Please post a screenshot of the strip rule.
  • 10.  RE: Clearpass with AD using Cert
    Posted Jun 13, 2018 04:54 PM
    Sure!
    Here is the screenshot
  • 11.  RE: Clearpass with AD using Cert
    Posted Jun 14, 2018 07:08 AM
    That looks correct. Please work with Aruba TAC.
  • 12.  RE: Clearpass with AD using Cert
    Posted Jun 18, 2018 11:48 AM
    Will do!
    Thanks for the help!
