Clearpass with Cisco switches MAB auth
  • 1.  Clearpass with Cisco switches MAB auth
    Posted Feb 23, 2018 09:40 AM
    Hi all,
    I have a possible client which has mixed Cisco - HPE switches insfrastucture.
    I got 3 cisco switches from client and all Cisco switches fail with Clearpass  MAC autentication.
    Clearpass throw 209 error
    Error Code:
    209
    Error Category:
    Authentication failure
    Error Message:
    No password in request
     Alerts for this Request
    RADIUSMAC_AUTH: No password in request. Not attempting MAC authentication
    Cannot select appropriate authentication method
    Cisco 3750X configuration
    Switch#show running-config
    Building configuration...
    Current configuration : 4281 bytes
    ! Last configuration change at 12:01:50 UTC Fri Feb 23 2018 by admin
    ! NVRAM config last updated at 10:06:05 UTC Fri Feb 23 2018 by admin
    version 12.2
    no service pad
    service timestamps debug datetime msec
    service timestamps log datetime msec
    no service password-encryption
    hostname Switch
    boot-start-marker
    boot-end-marker
    enable secret 5 $1$ykzb$3mQhJsjo/dCTptF5AN5j40
    username admin privilege 15 password 0 admin
    aaa new-model
    aaa authentication login testas local
    aaa authentication dot1x default group radius
    aaa authorization network default group radius
    aaa session-id common
    switch 2 provision ws-c3750x-24
    system mtu routing 1500
    ip domain-lookup source-interface Vlan177
    ip name-server 8.8.8.8
    crypto pki trustpoint TP-self-signed-4086047360
    enrollment selfsigned
    subject-name cn=IOS-Self-Signed-Certificate-4086047360
    revocation-check none
    rsakeypair TP-self-signed-4086047360
    crypto pki certificate chain TP-self-signed-4086047360
    certificate self-signed 01
    3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
    31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
    69666963 6174652D 34303836 30343733 3630301E 170D3933 30333031 30303031
    32355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
    4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30383630
    34373336 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
    8100ADD8 21B767E5 7B4BDB3B F4F6DBE3 E4EF7D22 80F440CF EC6A3412 AE5DC72E
    8AD6CE76 84D8C9DC B19664C6 6D677143 FE1EF96D C544A3AE F29C99F6 E508F11E
    CD1CC649 ED610A15 0CFCEE8F 05B1CE32 1C0EB3B4 18B673F3 A5F08512 89FBBF9E
    5D3FD3D3 CCC19BDA E7D81BBD 520F189B 32471928 9F096AAD A7171EAA A3418E71
    B6770203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
    551D1104 0B300982 07537769 7463682E 301F0603 551D2304 18301680 144DE7D5
    C032F8D6 6D038B0E 26BE1F5B 827C338B 2F301D06 03551D0E 04160414 4DE7D5C0
    32F8D66D 038B0E26 BE1F5B82 7C338B2F 300D0609 2A864886 F70D0101 04050003
    81810009 25834ED0 40D5E759 B7830546 619C7EE3 F2404CA4 95B436DE 2A391A44
    3E9EC6EF DC8A86CB 83EEE40F 562FC198 38669771 972BC08D B4728177 80788EBA
    1878114B FB87B175 E86024B3 FCA46B3F 266E35E3 6DAD1C60 BEE10020 BDDA022A
    951E996C 17C9CA7E A1DFB1ED 7C1BC8C6 46F3F871 603942F5 5C18F03D 7E114819 C4AB86
    quit
    dot1x system-auth-control
    spanning-tree mode pvst
    spanning-tree extend system-id
    vlan internal allocation policy ascending
    interface FastEthernet0
    no ip address
    shutdown
    interface GigabitEthernet2/0/1
    switchport mode access
    authentication port-control auto
    dot1x pae authenticator
    interface GigabitEthernet2/0/2
    mab eap
    interface GigabitEthernet2/0/3
    interface GigabitEthernet2/0/4
    interface GigabitEthernet2/0/5
    interface GigabitEthernet2/0/6
    interface GigabitEthernet2/0/7
    interface GigabitEthernet2/0/8
    interface GigabitEthernet2/0/9
    interface GigabitEthernet2/0/10
    interface GigabitEthernet2/0/11
    interface GigabitEthernet2/0/12
    interface GigabitEthernet2/0/13
    interface GigabitEthernet2/0/14
    interface GigabitEthernet2/0/15
    interface GigabitEthernet2/0/16
    interface GigabitEthernet2/0/17
    interface GigabitEthernet2/0/18
    interface GigabitEthernet2/0/19
    interface GigabitEthernet2/0/20
    interface GigabitEthernet2/0/21
    interface GigabitEthernet2/0/22
    interface GigabitEthernet2/0/23
    interface GigabitEthernet2/0/24
    switchport trunk encapsulation dot1q
    switchport mode trunk
    switchport nonegotiate
    interface GigabitEthernet2/1/1
    interface GigabitEthernet2/1/2
    interface GigabitEthernet2/1/3
    interface GigabitEthernet2/1/4
    interface TenGigabitEthernet2/1/1
    interface TenGigabitEthernet2/1/2
    interface Vlan1
    no ip address
    shutdown
    interface Vlan177
    ip address 192.168.77.94 255.255.255.0
    ip default-gateway 192.168.77.1
    ip classless
    ip http server
    ip http secure-server
    snmp-server community testas RW
    radius-server host 192.168.77.80 auth-port 1812 acct-port 1813 key testas
    line con 0
    line vty 0 4
    login authentication testas
    transport input telnet
    transport output telnet
    line vty 5 15
    ntp clock-period 36027705
    ntp server 91.207.136.55
    end
    Clearpass configuration
    Maybe anyone have some ideas how to resolve this, maybe my cisco switches configuration is bad or clearpass configuratio  need any addtional configuration?
    Maybe MAB request format should be changed?
    Please help, its possible large deal form me :)
    If someone have any ideas I can add full clearpass configuration
    Attachment(s)
    zip
    DashboardDetails.zip   6 KB 1 version
  • 2.  RE: Clearpass with Cisco switches MAB auth
    Posted Feb 23, 2018 09:42 AM
  • 3.  RE: Clearpass with Cisco switches MAB auth
    Posted Mar 05, 2018 03:26 AM
    Thank you, this doc solved my problems :)
  • 4.  RE: Clearpass with Cisco switches MAB auth
