Clearpass with Unmanaged Switch
  • 1.  Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 10:04 AM
    Guys,
    Aruba 3810: latest FW
    Cisco 2960X latest FW
    My deployment is to perform 802.1x and MAC auth failover. Everything works fine accept for the unmanged switch connected to the aruba (3810) and cisco switch (2960x)
    when the unmanaged switch connected to the aruba & cisco switch, only the 1 user managed to perform authentication, once the next user authenticate, the existing user will be disconnected.
    please help..
  • 2.  RE: Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 10:39 AM
    So, in this case you would be doing mac-authentication for clients connected to the unmanaged switch since, as an unmanaged switch it can't be a RADIUS client, correct?
    Have you configured the mac-authentication client-limit on the downlink port from the 3810?  I believe it defaults to 1, but can be increased to as many as 32.  I'm not sure what the Cisco equivalent would be off the top of my head, but I have to assume they have something similar.
    Edit:  Thinking a bit further on this, you should also be able to do 802.1X as well as long as it is enabled on the downlink port to the unmanaged switch.  However, in either case you will still need to increase the client-limit on that port (for both mac-auth and the .1X configuration).
  • 3.  RE: Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 11:10 AM
    my configuration for the port includes:
    aaa port-access mac-based 2-24 addr-limit 24
    aaa port-access authenticator 2-24 client-limit 24
    but still only 1 user able to authenticate if using unmanaged switch
    for cisco im looking at multi authentication mode.
  • 4.  RE: Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 01:59 PM
    Are you using Clearpass to set any access parameters (ACLs, VLAN assignment, ect...)?  If you are, the properties of the downlink port to the unmanaged switch would be set based on the most recent successful authentication.
  • 5.  RE: Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 02:27 PM
    The configuration you are using should work. Most times we are using this with for clients behind an IP phone. Are you using mac or dot1x authentication at the clients? Is something like port security configured at the switch?
    Like Bill already asked. The client limit at the Aruba switch can dynamically changed. Are you using this?
    Please could you share the output of the following command from the switch?
    show port-access config
    show port-access clients detailed <portnumber>
    Do you see more the one authentication request at cppm?
    For Cisco you should indeed use the multi authentication mode.
    Willem
  • 6.  RE: Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 07:33 PM
    It's working for ip phones and the device behind ip phones for both Aruba and Cisco switch. Currently I'm using mutli domain for Cisco and pushing default voice class attributes from clearpass to make the phones get voice vlan configured at the port
    Not sure whether phone still works If the same attributes is pushed when using multi authentication
  • 7.  RE: Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 10:43 PM
    below is the output as requested:
    Aruba-3810# show port-access config
    Port Access Status Summary
    Port-access authenticator activated [No] : Yes
    Allow RADIUS-assigned dynamic (GVRP) VLANs [No] : No
    Use LLDP data to authenticate [No] : No
    802.1X 802.1X Web Mac LMA Cntrl Mixed Speed
    Port Supp Auth Auth Auth Auth Dir Mode VSA MBV
    1 No No No No No both No No Yes
    2 No No No No No both No No Yes
    3 No No No No No both No No Yes
    4 No No No No No both No No Yes
    5 No No No No No both No No Yes
    6 No Yes No Yes No in No No Yes
    7 No Yes No Yes No both No No Yes
    8 No No No No No both No No Yes
    9 No No No No No both No No Yes
    10 No No No No No both No No Yes
    11 No No No No No both No No Yes
    12 No Yes No No No in No No Yes
    13 No Yes No Yes No in No No Yes
    15 No Yes No Yes No in No No Yes
    16 No Yes No Yes No in No No Yes
    17 No Yes No Yes No in No No Yes
    18 No Yes No Yes No in No No Yes
    19 No Yes No Yes No in No No Yes
    20 No Yes No Yes No in No No Yes
    21 No Yes No Yes No in No No Yes
    22 No Yes No Yes No in No No Yes
    23 No Yes No Yes No in No No Yes
    24 No Yes No Yes No in No No Yes
    A1 No No No No No both No No Yes
    A2 No No No No No both No No Yes
    A3 No No No No No both No No Yes
    A4 No No No No No both No No Yes
    port-access
    port-security
    portal
    Aruba-3810# show port-access clients detailed
    [ethernet] PORT-LIST Show information for specified ports only.
    <cr>
    Aruba-3810# show port-access clients detailed 13
    Port Access Client Status Detail
    Client Base Details :
    Port : 13 Authentication Type : 802.1x
    Client Status : authenticated Session Time : 116 seconds
    Client name : shaiful Session Timeout : 10800 seconds
    MAC Address : e46f13-f4c209
    IP : n/a
    Access Policy Details :
    COS Map : Not Defined In Limit Kbps : Not Set
    Untagged VLAN : 352 Out Limit Kbps : Not Set
    Tagged VLANs : No Tagged VLANs
    Port Mode : 1000FDx
    RADIUS ACL List :
    permit in ip from any to any
    Captive Portal Details :
    URL :
    Port : 13 Authentication Type : mac-based
    Client Status : authenticated Session Time : 145 seconds
    Client Name : a44cc80e07ff Session Timeout : 10800 seconds
    MAC Address : a44cc8-0e07ff
    IP : n/a
    Untagged VLAN : 358 Out Limit Kbps : Not Set
    Port Mode : 1000FDx
    RADIUS ACL List :
    URL :
    Client Status : authenticated Session Time : 156 seconds
    Client Name : c8d3ffd9fd66 Session Timeout : 10800 seconds
    MAC Address : c8d3ff-d9fd66
    IP : n/a
    Port Mode : 1000FDx
    RADIUS ACL List :
    URL :
    hub connected to the cisco is  resolved using multi-auth
    for aruba switch 3810, can be connected using hub/unmanagegd switch but need to manually plug in and plug out
  • 8.  RE: Clearpass with Unmanaged Switch
    Posted Dec 28, 2017 07:30 PM
    Clearpass only push acl to the switch. Clients will get whatever access vlan already configured at the port
