last person joined: 11 hours ago
Clearpass XML API and Python 3
  • 1.  Clearpass XML API and Python 3
    Posted Feb 04, 2015 02:13 PM
    I'm trying to access the Clearpass XML API to retrieve information about Endpoints.
    I'm trying to use the following python 3 script:
    import urllib.request
    import xml.etree
    theurl = 'http://<server>/tipsapi/config/read/Endpoint'
    username = '<user>
    password = '<secret>'
    xml_string = '''
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <TipsApiRequest xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
    <TipsHeader version="3.0" source="Endpoint"/>
    <Filter entity="Endpoint">
    <Criteria fieldName="macAddress" filterString="a82066166659" match="equals" />
    </Filter>
    </TipsApiRequest>
    passman = urllib.request.HTTPPasswordMgrWithDefaultRealm()
    # this creates a password manager
    passman.add_password(None, theurl, username, password)
    # Because with have put None at the start it will always
    # use this username/password combination for urls
    # for which 'theurl' is a super-urllib
    authhandler = urllib.request.HTTPBasicAuthHandler(passman)
    # create the authhandler
    opener = urllib.request.build_opener(authhandler)
    urllib.request.install_opener(opener)
    # All calls to urllib.urlopen will now use our handler
    # Make sure not to include the protocol in the URL, or
    # HTTPPasswordMgrWithDefaultRealm will be very confused.
    # You must (of course) use it when fetching the page though.
    xml_string = xml_string.encode('utf-8')
    req = urllib.request.Request(theurl)
    req.add_header("Content-Type", "application/xml")
    pagehandle = urllib.request.urlopen(req, xml_string)
    # authentication automatically handled for username
    print(pagehandle.read().decode('utf-8'))
    The script runs, but returns a list of all endpoints, not just the one I'm searching for.
    It's either a python 3 issue, or a filter issue, I can't determine which.
    Thanks in advance.
    -Neil
  • 2.  RE: Clearpass XML API and Python 3
    Posted Feb 09, 2015 10:29 AM
    Well it was a python 3 issue:
    Here is the working script:
    import urllib.parse
    theurl = 'https://<SERVER>/tipsapi/config/read/Endpoint'
    username = '<username>'
    password = '<password>'
    # Note: no return after ''' or you will have issues.
    xml_string = '''<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <TipsHeader version="6.4" source="Endpoint"/>
    <Criteria fieldName="macAddress" filterString="a82066166659" match="equals"/>
    </Filter>
    </TipsApiRequest>'''
    passman.add_password(None, theurl, username, password)\
    data = xml_string.encode('utf-8')
    # Convert Python3 String to Bytes
    req = urllib.request.Request(theurl, data)
    req.add_header("Content-Type","application/x-www-form-urlencoded;charset=utf-8")
    pagehandle = urllib.request.urlopen(req)
    # print results
  • 3.  RE: Clearpass XML API and Python 3
    Posted Feb 23, 2015 01:11 PM
    Attached are three python 3 CGI scripts to enable, disable, and find disabled  hosts using the clearpass XMI API.
    They're pretty crude, but enough for a proof of concept.
    Enjoy.
    Attachment(s)
