Clearpass/PAN Wired MAB User-id Issue
  • 1.  Clearpass/PAN Wired MAB User-id Issue
    Posted Jul 13, 2017 11:52 AM
    I have been following several guides by Danny Jump,
    ClearPass 6.X and PANW Integration V5
    and
    PANW and CPPM Advanced Deployment use-case TechNote (V2-July 2014).pdf
    Which have helped with the wireless integration but I'm missing something in the enforcement policy or profile because wireless. I do not see an accounting tab on the access Tracker but the username is being populated correctly from the Guest Device Repository. I see the IP being updated in the EP database. I can provide more information just not sure where to go next.
    Rosie
  • 2.  RE: Clearpass/PAN Wired MAB User-id Issue
    Posted Jul 13, 2017 11:57 AM
    What kind of switch?
  • 3.  RE: Clearpass/PAN Wired MAB User-id Issue
    Posted Jul 13, 2017 12:09 PM
    Only the best, Alcatel.
  • 4.  RE: Clearpass/PAN Wired MAB User-id Issue
    Posted Jul 14, 2017 11:56 AM
    I have the following configurations on the Alcatel switch
    aaa radius-server "Clearpass" host x.x.x.x <other stuff> auth-port 1812 acct-port 1813
    aaa authentication mac Clearpass
    aaa accounting mac Clearpass
    802.1x 1/31 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
    802.1x 1/31 supplicant bypass enable
    802.1x 1/31 captive-portal session-limit 12 retry-count 3
    802.1x 1/31 captive-portal inactivity-logout disable
    802.1x 1/31 supp-polling retry 10
    802.1x 1/31 supplicant policy authentication pass group-mobility default-vlan fail block
    802.1x 1/31 non-supplicant policy authentication pass group-mobility block fail default-vlan
    802.1x 1/31 captive-portal policy authentication pass default-vlan fail block
  • 5.  RE: Clearpass/PAN Wired MAB User-id Issue
    Posted Jul 14, 2017 01:53 PM
    I see data coming in the live monitoring->accounting but not under a tab for the connection in Access Tracker. What I'm also not seeing come across from multiple switch vendors is Framed IP Address. I'm wondering if this is why I'm not seeing the data in PAN.
