CLI command for POE to power up the IAP-135?
  • 1.  CLI command for POE to power up the IAP-135?
    Posted Jun 10, 2014 03:30 AM
    Currently, I am doing a setup with a Aruba A620 controller and a IAP-135.
    The PoE port of the controller is connected to the ENET0 port of IAP-135.
    However, the controller did not power up the IAP-135.
    What is the CLI command to power up?
    Please advise.
  • 2.  RE: CLI command for POE to power up the IAP-135?
    Posted Jun 10, 2014 04:22 AM
    1.only the 4 ports at the bottom got poe support.
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/620-maximum-PoE-ports/td-p/30718
    2.When (and if) you "factory defaulted", did you use "write erase all" or just "write erase"?  The "write erase all" command erases the licenses.  There is a license on all 6xx series controllers that enables PoE.  If you deleted this, you will need to call support and get it re-enabled (or import the previous licenses that you backed up before you erased them).
  • 3.  RE: CLI command for POE to power up the IAP-135?
    Posted Jun 10, 2014 05:35 AM
    Thanks kdisc98,
    I unintentionally write erase all (removed all licences).
    I have already resolved this issue. Thanks
  • 4.  RE: CLI command for POE to power up the IAP-135?
    Posted Jun 10, 2014 04:38 AM
    show license to see if you have Poe license loaded?
  • 5.  RE: CLI command for POE to power up the IAP-135?
    Posted Jun 10, 2014 04:39 AM
    yep,after enable
    just show lic
