cli command to show power on second port of Ap225
  • 1.  cli command to show power on second port of Ap225
    Posted Sep 30, 2016 05:24 AM
    HI,
    We are deploying a AP225 as a RAP, wireless all looks fine but when we connect a further connection to the second ethernet port we are not able to see any led active on it. We want to send these off to different places and want to be able to do a command to see if the AP doesnt have sufficient PoE to power it so we can advise accordingly. We have been successful with one or two switches, I am guess that the switch needs PoE+? Not sure of the officilal requirement for the second port. Any ideas on both? Thanks!
  • 2.  RE: cli command to show power on second port of Ap225
    Posted Sep 30, 2016 06:49 AM
    You need POE+ on a single port for the second ethernet port to work.
  • 3.  RE: cli command to show power on second port of Ap225
    Posted Sep 30, 2016 06:52 AM
    Thanks for configrming its PoE+ cjoseph but is there a copmmand to see what power (poE) its receiving?
  • 4.  RE: cli command to show power on second port of Ap225
    Posted Sep 30, 2016 06:57 AM
    show ap debug system-status ap-name <name of ap> | begin "Power Status"
    The output should look like this:
    Power Status
    Operational State          POE-AT: No restrictions
    Current HW State           POE-AT: No restrictions
  • 5.  RE: cli command to show power on second port of Ap225
    Posted Sep 30, 2016 07:08 AM
    Thanks, I am getting this on a CAP AP225:- Can you explain how we know this is getting enough power for second port. Not sure what refers to whether it has PoE+ as opposed to PoE?
    Power Status
    LLDP Negotiated POE Power  13.0W
    Bandwidth Contracts Information
    Received BWM Config:
            ACL                                                            DIR  Contract-ID PerUser UseCount Rate
    Allocated Contracts:
    Contract-ID Rate       UseCount Available-Bytes Max-Bytes Policed-Bytes
  • 6.  RE: cli command to show power on second port of Ap225
    Posted Sep 30, 2016 07:19 AM
    This is all you need.
  • 7.  RE: cli command to show power on second port of Ap225
    Posted Sep 30, 2016 07:24 AM
    To be clear, "Operational State" is the end-result
  • 8.  RE: cli command to show power on second port of Ap225
    Posted Sep 30, 2016 11:49 AM
    Thanks again cjoseph. Got it.
