CLI commands for AP 275
  • 1.  CLI commands for AP 275
    Posted Apr 11, 2014 07:06 PM
    Trying to setup AP 275 with static ip thru CLI for a static IP envirenment . None of the old commands work ('setenv' or '?'). Is there a document available? Any help is appreciated.
    apboot> printenv
    Unknown command 'print' - try 'help'
    apboot>setenv ipaddr 192.168.1.1
    Unknown command 'setenvsetenv' - try 'help'
    apboot>
  • 2.  RE: CLI commands for AP 275
    Posted Apr 15, 2014 09:49 AM
    You might want to open a TAC case. All of the apboot commands are working fine on my 275.
  • 3.  RE: CLI commands for AP 275
    Posted Apr 15, 2014 12:27 PM
    Thanks for the reply.
  • 4.  RE: CLI commands for AP 275
    Posted Apr 15, 2014 03:47 PM
    I had flow control set to xon/xoff even though the terminal window opened and responded to 'Enter' command. I changed flow control to "none" and it started to work fine. TAC found the problem…
