CLI Configuration on Instant AP
  • 1.  CLI Configuration on Instant AP
    Posted Apr 02, 2013 04:35 AM
    Is there any future plan to provide CLI based configuration for Instant IAP. AirWave (AMP) can push the template based configuration to IAPs. Is there any interface available on IAP for any thirdparty tool to push the template based configuration file into it.
    Tuhin
  • 2.  RE: CLI Configuration on Instant AP
    Posted Apr 02, 2013 04:37 AM
    You may use your console port - in order to push full config. (push the template based configuration)
  • 3.  RE: CLI Configuration on Instant AP
    Posted Apr 02, 2013 05:45 AM
           Thanks. Console based configuration will meet my current need.
           Will it be possible for you to share a high-level flow on how AMP pushes the full configuration into IAP.
    Tuhin
  • 4.  RE: CLI Configuration on Instant AP
