Cloud Managed Networks
CLI Configured Switrches - Added to Aruba Central
This thread has been viewed 29 times
  • 1.  CLI Configured Switrches - Added to Aruba Central
    Posted Jan 11, 2021 11:31 AM
    I have a quick question:
    I have about 20 Aruba 2930M Switches that were configured using CLI and are ] live in production.
    The customer wants to add them to Aruba Central, for Management etc.
    Is there and what is the procedure to add them to Central, and would I need to reconfigure the switch or is it a seamless process.
    Also, are the 6300M Switch Family supported on Central or net yet ?
    Kind Regards
    Jaco
  • 2.  RE: CLI Configured Switrches - Added to Aruba Central
    Posted Jan 11, 2021 12:52 PM
    From my side, I prefer to start with a factory default configuration when adding switches to Central. However, it is possible to import the existing configuration as described here https://help.central.arubanetworks.com/2.5.2/documentation/online_help/content/switches/get-started/prov_tmplt_prcnf.htm
    For a list of supported devices check the latest Central documentation (2.5.2 as of today) - 6300m is supported in template mode
    https://help.central.arubanetworks.com/2.5.2/documentation/online_help/content/nms/overview/supported_devices.htm
    Ayman Mukaddam
  • 3.  RE: CLI Configured Switrches - Added to Aruba Central
    Posted Jan 11, 2021 05:13 PM
    Thanx for the reply.
    I followed the steps in the document, however I get the below results on the switch
    I did configure NZTP, and DNS, and is able to ping the server address from the switch
    I did enter:  activate provision enable & activate provision force
    I also did add it on Central.
    (when this switch is Factory Defaulted - it does connect to Central, but not with a config already on)
    GWHQ-CAB_G-01# sh aruba-central
     Configuration and Status - Aruba Central
      Server URL              : https://device-eu.central.arubanetworks.com/ws
      Connected               : No
      Mode                    : NA
      Last Disconnect Time    : NA
      Server DNS Lookup       : Success
      Proxy Server DNS Lookup : NA
      Error Reason            : TLS generic error (code: -5901)
    AND -------------------------------------
    Configuration and Status - Activate Provision Service
      Activate Provision Service   : Enabled
      Activate Server Address      : device.arubanetworks.com
      Activation Key               : GC01CTHT
      Time Sync Status             : Time sync from NTP pool
      Activate DNS Lookup          : Success
      Activate Connection Status   : Failure
      Error Reason                 : Activate provision has failed because of
     invalid response received from server with status code : success
    Jaco Janse van Rensburg
  • 4.  RE: CLI Configured Switrches - Added to Aruba Central
    Posted Jan 13, 2021 10:54 AM
    What is the code that you are currently running?
    Can you run the following command on the switch:
    show crypto pki ta-profile
