CLI to trace roles/policies associated to a SSID
  • 1.  CLI to trace roles/policies associated to a SSID
    Posted Jul 14, 2016 09:44 AM
    I want to get a listing of the roles associated to a SSID. Then list the policies associated to the roles.
    I know it is something real simple but I am just drawing a blank.
  • 2.  RE: CLI to trace roles/policies associated to a SSID
    Posted Jul 14, 2016 10:13 AM
    Are you using a RADIUS server to return roles back to the controller ?
    Because if that's the case then you won't be able match roles to SSIDs in that way
    But if you are not returning user roles from RADIUS you can take a look at AAA profiles assigned to each virtual AP and look at the role that is getting applied
    Also you can use the show reference button or command
    http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-The-power-of-the-quot-show-reference-quot-button/td-p/1710
    Get Outlook for iOS
