Dear community
We have an Clickshare in our Wifi. In general it works but one issue still occurs. If you search the Basis Unit in the mobile App you don't get the Base Unit in the search list. But when you enter the IP address from the Base Unit by hand you can connect.
From my point of view it is an issue with multicast. Can some help how to check this or do the correct setting?
Maybe it's important, we did an upgrade from 8.1.0 to 8.2.0.1 yesterday.
Thanks for helping.
