client AP downstream of mesh failing to receive DHCP offer
  • 1.  client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 01:42 PM
    Almost at wits end, I feel that this is probably a switch config issue, but I'm clearly missing something so if any of this sounds familiar and anyone has any advice I'd be glad of the help:
    Running 6.4.3.4
    Point to point mesh
    Cisco <----> AP <**** mesh ****> AP <----> HP <----> 1 x AP
    2960cx         274                             274          2920        277
    The mesh link seems to come up fine.
    AP277 attached to switch downstream of mesh with our normal, non-mesh config sends DHCP discovers but never receives offers. I see the offers on the switch upsteam of the mesh (on the port connected to the portal) but the offers never make it across the mesh to the point switch.
    I am sending the AP management vlan untagged across the mesh, and the switch management Vlan is 1400, that's going across tagged. The wired-ap-profiles (one for portal, one for point):
    Wired AP profile "cam-guild_portal-wiredap"
    Parameter Value
    Wired AP enable Enabled
    Trusted Trusted
    Forward mode tunnel
    Switchport mode trunk
    Access mode VLAN 1
    Trunk mode native VLAN 1
    Trunk mode allowed VLANs 1,1400
    Broadcast Broadcast
    Wired AP profile "cam-guild_wiredap"
    Parameter Value
    Trusted Trusted
    Forward mode bridge
    Access mode VLAN 1
    Broadcast Broadcast
    Just to make things more complicated the switch at the portal end is Cisco 2960cx, and the switch downstream of the mesh is HP 2920. Switch config for link to portal:
    interface GigabitEthernet0/1
    switchport trunk native vlan 3118
    switchport trunk allowed vlan 1400,3118
    switchport mode trunk
    switchport nonegotiate
    ip arp inspection trust
    power inline static
    srr-queue bandwidth share 1 30 60 10
    priority-queue out
    storm-control broadcast level 5.00
    no cdp enable
    no lldp med-tlv-select network-policy
    spanning-tree portfast trunk
    spanning-tree bpdufilter enable
    spanning-tree guard root
    end
    Config for link to point:
    interface 23
    broadcast-limit 5
    poe-allocate-by value
    poe-value 30
    dhcp-snooping trust
    tagged vlan 1400
    untagged vlan 3118
    no port-security eavesdrop-prevention
    spanning-tree bpdu-filter
    arp-protect trust
    exit
    Link to non-mesh AP:
    interface 1
    broadcast-limit 5
    poe-value 30
    untagged vlan 3118
    spanning-tree admin-edge-port
    spanning-tree root-guard
    exit
    I'm going round in circles so any help much appreciated!
    Guy
  • 2.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 01:53 PM
    See if this helps,
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-807
    Rajaguru Vincent
  • 3.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 02:17 PM
    Thanks for replying but that link gives me a choice of 3 articles, and I'm not sure which you're referring to?
  • 4.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 02:18 PM
    Thanks for replying, but that link takes me to 3 articles, I'm not sure which you're referring to?
  • 5.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 02:26 PM
    Something went wrong with copy-paste. This one should work.
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-should-the-Aruba-controller-be-configured-to-ensure-proper/ta-p/177158
    Rajaguru Vincent
  • 6.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 02:29 PM
    Something breaks when I paste links,
    You can try searching the community knowledge base for the article titled,
    "How should the Aruba controller be configured to ensure proper VLAN tagging across a mesh bridge link?"
    Rajaguru Vincent
  • 7.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 06:26 PM
    Thanks for this, interesting reading. I will implement it tomorrow and let you know...
    Guy
  • 8.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 06:30 PM
    Is this IAP (Instant) or AOS (controller) based? Just wanting to make sure...
  • 9.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 06:32 PM
    Controller based...
  • 10.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 07, 2015 06:44 PM
    So this may or may not be relevant. Because you are running in tunnel mode, and without knowing exactly what the port config is on every relevant connection point, know that whatever comes across the wired interface on the 274 mesh link is tunneled all the way back to the controller. SO if you have VLANs configured on the switches you noted, but NOT on the controller, I assume 3118, then there wouldn't be L2 from the controller out to the har side HP2920.
    You also seem to have one profile that is tunnel mode and one that is bridge. At least on the 274s they need to match (either both bridge or both tunnel). The 277 off the 2920 should just be a normal Campus AP. Worst comes to worse, take the switches out of the equation (at least on the HP side) and test to see if you have continuity over the mesh link. If you can make it to the HP2920 from the network, then at least you know the native VLAN is up (whatever that is, either VLAN 1 or VLAN 3118, depending on how they are hooked up).
  • 11.  RE: client AP downstream of mesh failing to receive DHCP offer
    Posted Dec 08, 2015 12:00 PM
    Thanks for this info, we had to send the equipment out for deployment today so I cannot test any more. However nothing I tried solved the problem, DHCP offers not received by client APs. The mesh was reliable (in terms of coming up) so we are installing the switch and APs in the next day or two, I'll have to work remotely and hope I don't do anything stupid to cut myself off!
    We did find something in the release notes for 6.4.3.5 which may be relevant:
    Symptom: Broadcast traffic from a switch to mesh point's Ethernet 0 was
    sent back. This issue is resolved by removing eth0 from bond0 interface.
    Scenario: This issue occured when a client or a switch connected to mesh
    points relayed broadcast traffic. This issue was observed when a client or
    a switch was connected to a mesh point's Ethernet 0Platform: All
    platforms.
    Reported Version: ArubaOS 6.4.3.2.
    Bug ID 124682, 126989
    We'll try a firmware upgrade after installation to see if that solves it.
    Guy
