Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
Client Attack Detected - Gateway MAC
  • 1.  Client Attack Detected - Gateway MAC
    Posted Dec 15, 2022 11:30 AM
    I'm seeing lots of 'client attack detected' alerts that look like this (i've colour coded it for better reference):
    An AP (NAME AK-AP17 and MAC B8:3A:5A:C3:E6:84 on RADIO 1) detected a misassociation between valid client 7E:81:10:C9:34:D3 and access point (BSSID 70:4C:A5:86:9C:4C and SSID on CHANNEL 116) Association type is (Association To External AP) SNR of client is 17
    The AP and client MAC addresses are always different, but the consistent entry in every alert is the BSSID MAC address (70:4C:A5:86:9C:4C) which is the MAC address of the default gateway (in this case my FortiGate firewall) that has no WiFi capability. The gateway is also used for DHCP, DNS and NTP.
    Why am I getting these alerts? What exactly is the AP detecting to raise this alert?
    FW: AOS 8.7.1.2_79305
    Devices: AP-535
  • 2.  RE: Client Attack Detected - Gateway MAC
    Posted Dec 16, 2022 07:11 AM
    I would read this alert that the Access Point AK-AP17 which has the MAC address B8:5A...84 on 2.4GHz sees a packet in the air between the other two MAC addresses, which it did not send/receive themselves, but the client 7E:81...D3 has been connected to the AP in the past (which is definition of a valid client).
    It's known that some IDS signatures have false positives, this may be one of those. If you need this further investigated, I would involve Aruba Support. And if this happens a lot, and you have the possibility to run a wireless packet capture, you may try to capture those frames and get a better clue where these originate from. The SNR of 17 indicates that the AP is not too close to the AP, but probably 10-20m away from the AP.
