Client can't associate to WPA2/WPA3 ssid
  • 1.  Client can't associate to WPA2/WPA3 ssid
    Posted 2 days ago
    Hi everyone,
    I hope you're all doing well. I've encountered a strange issue after migrating my standalone controller to an MM hierarchy. Some devices can connect to open SSIDs but can't associate with WPA2/WPA3 SSIDs. The AP logs show "A constrained max client," even with only 2-3 clients connected to the AP. This issue affects all APs in my network, impacting devices like Samsung TVs and Nintendo Switches. I've attached a screenshot of the 802.11 management frame. Any help would be appreciated!
    Thanks!
  • 2.  RE: Client can't associate to WPA2/WPA3 ssid
    Posted 2 days ago
    Hi Joe,
    What version of AOS are you running? This may be fixed by upgrading perhaps.
  • 3.  RE: Client can't associate to WPA2/WPA3 ssid
    Posted 2 days ago
    8.10.0.13 , should be latest LSR version
  • 4.  RE: Client can't associate to WPA2/WPA3 ssid
    Posted 2 days ago
    What is max associations set to in the SSID profile? 64?
    If yes, try increasing max associations from 64 to something like 128 or 256.
  • 5.  RE: Client can't associate to WPA2/WPA3 ssid
    Posted 19 hours ago
    I gave it a try today, but I'm still facing the same issue with any WPA2/WPA3 SSID
    It connects straightforwardly with open SSIDs
  • 6.  RE: Client can't associate to WPA2/WPA3 ssid
    Posted 19 hours ago
    Are your clients WPA3 capable? The logs mention SAE, which is the WPA3 Equivalent of WPA2-PSK. WPA3-SAE is not backward compatible with WPA2-PSK, and if you have not enabled transition mode (which in fact configures 2 different SSIDs, one for WPA2 the other for WPA3), clients not supporting SAE may not be able to connect.
    I would for now try with WPA2 and see if that fixes the issue... and explore the options from there.
