Client connection requires constant resets
  • 1.  Client connection requires constant resets
    Posted Aug 25, 2020 08:21 AM
    I'm facing a bit of an odd issue.
    We have a cluster of 214 and 314 instant access points, primarily 214.
    Multiple times throughout the day, even though the devices are showing as connected, they will not be able to reach any resources. Having the device turn off/on their wireless, or reconnect to the SSID restores their access to the resources.
    the SSID the devices primarily connect to use eap-peap over mschap and TLS (clearpass for AAA)
    The clients are primarily windows 10 laptops, and iphones.
    I'm still gathering info on when this occurs, and what is happening to the devices traffic, but I wanted to reach out and see if anyone had experienced similar symptoms and had a solution.
