Client connectivity problems
  • 1.  Client connectivity problems
    Posted Apr 23, 2014 03:02 PM
    I've been having to reboot a few of our RAP's because our wifi users are not able to browse the internet. They do in fact authenticiate to the particular SSID, receive a proper IP address but cannot ping their gateway - according to the controller, they are not connected
    After rebooting the AP, the problem goes away - at least for a few days. It does not seem to affect AP's the are local to the controller.
    We've been pretty stable for 2 years now and we haven't done any changes to our networks...
    Aruba OS 6.2.1.5
    1-3600 controller
    27-RAP's
    5 LAN connected AP's
  • 2.  RE: Client connectivity problems
    Posted Apr 23, 2014 03:15 PM
    We need more information:
    Does your SSID use authentication/encryption?
    Is it tunneled or bridged?
    What is the CIR (WAN speed) of your links to remote sites?
    What clients are having this issue?
  • 3.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:17 PM
    We have 2 SSID's; 1 for guest and 1 for employees.
    guest uses captive portal and our employee network using a PSK with wpa2 encrypyion.
    Our link speed is 10 mbps - connection is tunneled.
    All devices seem to be affected when this happens...
  • 4.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:33 PM
    Do you have Drop Broadcast and Multicast enabled on Both Virtual APS?
  • 5.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:35 PM
    Negative.
  • 6.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:37 PM
    Please try turning it on....on Both Virtual APs...  Broadcasts being propagated on a campus network can hurt performance.  It is worse over the WAN...
  • 7.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:39 PM
    Thank you for the quick replies.
    I would like to make a correction: the tunnel mode is set to: split-tunnel.
  • 8.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:41 PM
    Okay.  Please turn it on, as well.  It still has an effect...
  • 9.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:45 PM
    Will do. And what about the "Broadcast-Filter ARP" in the statefull firewall setting?
  • 10.  RE: Client connectivity problems
    Posted Apr 23, 2014 04:47 PM
    Hold on.  Please Do not touch the stateful firewall settings.
    Broadcast Filter ALL and Broadcast Filter ARP should be turned on in Both Virtual APs, NOT the stateful firewall settings...
    http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/wlan_virtual_ap.htm
  • 11.  RE: Client connectivity problems
    Posted Apr 23, 2014 05:37 PM
    OK.
    I'm not seeing these setting on the webamin side...what is the comand that I need to issue to enable these 2 settings?
    Thanks.
  • 12.  RE: Client connectivity problems
    Posted Apr 24, 2014 05:13 AM
    Hi chuckster_ca,
    I think that the settings for Broadcast and Multicast are what I underline in the image attached.
    Massimo
    [If you found my post helpful, please give kudos]
  • 13.  RE: Client connectivity problems
    Posted Apr 24, 2014 11:47 AM
    Great, thanks.
    I've made the changes. I'll report back in a week.
  • 14.  RE: Client connectivity problems
    Posted Apr 30, 2014 03:18 PM
    All is good - thank you.
  • 15.  RE: Client connectivity problems
    Posted May 05, 2014 02:36 AM
    I am happy that is all ok!
    Have a good day,
    Massimo
