It should work with psk.
Original Message:
Sent: Jul 30, 2024 06:08 AM
Subject: Client device name instead of IP address
I enabled it in every single AAA profile, including Default. We are using WPA2 and WPA3 Personal. Might that be the problem?
Original Message:
Sent: Jul 30, 2024 06:01 AM
Are you sure you are enabling it in the right AAA profile?
Original Message:
Sent: Jul 30, 2024 05:56 AM
Tried without success. Left the devices off, deletet the dhcp lease, made sure that the controller forgot the device. Checked the option 12 box is marked.
Funny, that it worked, when the APs were IAPS. Just switched to the controller.
Original Message:
Sent: Jul 30, 2024 05:38 AM
The control has to witness the DHCP transaction. Turn the devices off for 10 minutes and then turn them back on. Or delete the devices from the user table on the wireless controller so that they can do a DHCP transaction again.
Original Message:
Sent: Jul 30, 2024 05:33 AM
Actually different devices. A Samsung S24 mobile, a Laptop running Win 10, a Laptop running Win 11 and a Laptop running Linux.
Original Message:
Sent: Jul 30, 2024 05:31 AM
What kind of device is it? It needs to re-dhcp, so disconnect it from the wireless and reconnect it.
Original Message:
Sent: Jul 30, 2024 05:27 AM
Hi cjoseph,
you mean deleting the DHCP lease on the Windows server? I did that but nothing changed.
Original Message:
Sent: Jul 30, 2024 05:09 AM
After enabling that option, you need to delete the device from the user table so that it can be discovered again. Some devices (like iPhones) no longer or never submit a hostname in the DHCP option.
Original Message:
Sent: Jul 30, 2024 05:02 AM
Sorry for bringing up that subject again.
I´ve checked the box to set the username from dhcp option 12. But it´s still the IP which is shown.
We use a Win 2022 server for DHCP. I´m not sure, if that´s the problem, but DNS and DHCP are working absolutely correct on the Windows side.
I´m somewhat clueless asking for help.
Best regards
Andreas
Original Message:
Sent: Mar 23, 2022 12:01 PM
Original Message:
Sent: Mar 23, 2022 11:17 AM
is there any way to display the client device name instead of IP address under the client list in Aruba controller?. The SSID is configured with PSK authentication. Under the client list only IP address is showing. Please see the image below.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/1b13a45e5fc74926831a52c5d6f0c043.png)
How to view the name?.
Ajin Skariah
