Client did not complete EAP transaction
This thread has been viewed 34 times
  • 1.  Client did not complete EAP transaction
    Posted Jul 05, 2019 04:02 AM
    I have met a problem. Some client is randomly TIMEOUT with code ERRORS 9002. ( 7 client/100 client)
    I implemented authenticated with basic mode (non TLS). Can anyone suggest how to fix this.
    Access TrackerAccess TrackerLogLog
    Thank you,
  • 2.  RE: Client did not complete EAP transaction
    Posted Jul 05, 2019 05:39 AM
    Hi ,
    It looks you are doing EAP-PEAP authentication by using AD as authentication source. In log what I see after user found in AD, CPPM server as sent EAP request MSCHPv2 Access challange identity to supplicant at 13:41:15 through NAD devcies (controller/switch) but it diidnt recevied any response and waited for 47 seconds and request get deleted.
    We need to look in to NAD device first whether it forwared server challange to supplicant or not, if it forward but client is not respoding then need to debug issue on cleint side.
  • 3.  RE: Client did not complete EAP transaction
    Posted Jul 05, 2019 05:43 AM
    NAS is 3COM switch, can you please suggest me how to collect the necessary. Below is configuration of the switch
    domain default enable clearpass
    gvrp
    dot1x
    dot1x timer quiet-period 10
    dot1x timer tx-period 10
    dot1x timer supp-timeout 60
    dot1x retry 10
    dot1x authentication-method eap
    undo dot1x handshake enable
    MAC-authentication domain clearpass
    radius scheme system
    radius scheme clearpass
    server-type standard
    primary authentication 192.168.9.10
    primary accounting 192.168.9.10
    secondary authentication 192.168.11.254
    security-policy-server 192.168.9.10
    key authentication pvp
    key accounting pvp
    user-name-format without-domain
    nas-ip 192.168.9.5
    accounting-on enable
    domain clearpass
    authentication radius-scheme clearpass
    accounting radius-scheme clearpass
    interface GigabitEthernet1/0/X
    port access vlan 9
    dot1x
  • 4.  RE: Client did not complete EAP transaction
    Posted Jul 05, 2019 06:32 AM
    https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c02581967
    Check for display radius statistics and port debugging, it will give idea.
  • 5.  RE: Client did not complete EAP transaction
    Posted Jul 05, 2019 05:46 AM
    can you check machine certificate installed on the Client machine?
  • 6.  RE: Client did not complete EAP transaction
    Posted Jul 07, 2019 09:58 PM
    I didn't check: "Verify the server's identity by validating the certificate" for all the computer.
    I make this simply by bypassing it.
    Kind Regards,
