Client History
  • 1.  Client History
    Posted Jan 09, 2014 11:02 AM
    I have an aruba 650 controller on 6.3
    Is there any way of viewing previously connected devices?  I am wanting to be able to tell my customer "On this date you had 'X' number of devices connected"
    Thanks in advance
  • 2.  RE: Client History
    Posted Jan 09, 2014 11:10 AM
    To be able to show history like you are asking about, you will need an external service like Aruba Airwave.
    The Controller does not save data like this for a long time, while Aruba Airwave logs this history for a long time.
  • 3.  RE: Client History
    Posted Jan 10, 2014 06:26 AM
    Thanks for your replies.
    We don't have an extrenal syslog server nor do we have airwave.  I dont see my customer buying airwave (but can always introduce him to it).  Do you think having an external syslog server is the best way to achieve my goal?
  • 4.  RE: Client History
    Posted Jan 10, 2014 06:41 AM
    If you are using 802.1x, you could make a report from the radius server, showing all devices/users that associate on the given date.
    Your radius server should allready log this.
  • 5.  RE: Client History
    Posted Jan 10, 2014 08:08 AM
    We have ClearPass and AirWave and both are sending syslogs (Splunk) which can build even more complex reports and data streams.
    There is a free version of Splunk available for commercial and non-commercial use that allows indexing of up to 500 MB of logs per day.
  • 6.  RE: Client History
    Posted Jan 09, 2014 12:36 PM
    Do you have an external syslog and if soo what type of authentication are you using for the clients?
    Yes, the preffered way would be some type of extenral monitoring device - Airwave is the best example here.
    But if you have stored logs depending on the auth type you might get the statistics you are looking for.
  • 7.  RE: Client History
    Posted Jan 10, 2014 03:01 AM
    In the syslog server, What type of authentication is required to store such data?
