Client info on Instant APs
  • 1.  Client info on Instant APs
    Posted May 22, 2014 01:39 PM
    Finally getting around to testing my IAP units.   We wanted to test 802.11ac, and have deployed an AP-225.
    How can I see if the clients are connecting at AC, or some other rate?  I see the type is AN, but I guess they want to know if they are connecting at full AC so they can test the throughput and range.
  • 2.  RE: Client info on Instant APs
    Posted May 22, 2014 01:43 PM
    Show ap association from the CLI.
  • 3.  RE: Client info on Instant APs
    Posted May 22, 2014 01:44 PM
    In the WebUI you can expand the Clients pane:
    Same box but expanded so you can actually see what I was referring to...
    And here is the "show ap association" command Cappalli pointed out.   The client I circled above is the same client below and is a Galaxy S4.  The nice thing about "show ap association" is you can see the number of Spatial Streams of the client.
    Expanded....
