Could it be that your client moved out of range of the AP and roamed to another AP (from AP xxx014 to AP xxxx002, and later to AP xxxxx007)? That is what the message says and that would not be an issue but normal behavior that clients roam to the closest/strongest AP.
Do you clients actually experience problems with the connectivity?
Original Message:
Sent: Mar 22, 2023 01:06 AM
Subject: Client is disconnected because of "Wlan driver wireless client out of range" an 535 AP
Hi all,
I'm facing an issue that clients are disconnected from the wireless because of "WLAN driver wireless client out of range."
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/8ab390ca833e47b7bd1ca598782d04a0.png)
Client is running on ax mode.
I saw these bugs were fixed on 8.10.0.0, and It was observed in AP-635 and AP-655 access points, but my controllers are on AOS 8.10.0.5, and the issue is on 535 AP.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/ddb36f1aca1b4272b17316fc651991e8.png)
Has anyone else run into the same problem?
Thanks for your reply.
