Client Match Log
  • 1.  Client Match Log
    Posted Jan 01, 2016 03:40 PM
    FInally mangaged to stabilise my iphone from randomly disconnecting, but whilst browsing CM history, there are numerous entries like this...
    Client left        0      14:28:43
    Client left        1      14:28:43
    Client associated 0 14:28:43
    I understand that the 0 & 1 are under the radio column, but what radio is it referring to?
    As far as i have mine set up, i have 5G on 0 and 2.4 on 1, with no way that the 5G clients can connect to 1 without the passphrase.
    Basically im just a bit confused as to why my phone would leave both radios, only to join again at exactly the same time!
  • 2.  RE: Client Match Log
    Posted Jan 10, 2016 02:39 AM
    Anyone??
    I am seeing long lists of these over a short spsce of time.
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      00:41:59
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      00:42:23
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      00:43:20
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      00:43:20
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      00:44:00
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      00:44:50
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      00:44:50
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      01:05:02
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      01:05:42
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      01:05:42
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      01:32:58
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      01:41:47
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      01:41:47
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      02:01:03
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      02:01:59
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      02:01:59
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      02:29:08
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      02:30:02
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      02:30:02
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      02:57:14
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      02:58:26
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      02:58:26
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      03:25:19
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      03:26:19
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      03:26:19
    cc:20:e8:78:15:ef  Normal     Normal     Client associated  0      03:38:25
    cc:20:e8:78:15:ef  Normal     Normal     Client left        0      03:39:11
    cc:20:e8:78:15:ef  Normal     Normal     Client left        1      03:39:11
  • 3.  RE: Client Match Log
    Posted Jan 10, 2016 07:01 AM
    Which version of Aruba Instant is this?
  • 4.  RE: Client Match Log
    Posted Jan 10, 2016 07:43 AM
    Hi Colin,
    Its 6.4.3.4-4.2.1.0_52602
    I have another iphone that has also done this, (on the 2.4 radio).
