Wired Intelligent Edge
Client Match makes user briefly disconnect
  • 1.  Client Match makes user briefly disconnect
    Posted Jul 18, 2016 10:23 AM
    We recently opened a new office area, with an Aruba solution.
    A couple clients told me they get a brief interruption of their wireless connection sometimes, randomly.
    I used one client as test subject, and setup a debug on her MAC address. I have now figured out that Client Match is causing her to connect to another access point.
    Imagine the office to be a rectangle shaped open office. We have two AP's, one on each "short" side of the rectangle. The test user always sits on here steady place, and never moved her laptop, but still I'm seeing her disconnect and connect to the other AP.
    I noticed this message in the debug log:
    ## deauth from AP 261 (left side office)##
    Jul 18 07:46:52 :501080:  <NOTI> |AP NDHAM01AP261@10.25.34.31 stm|  Deauth to sta: 34:02:86:a6:bb:3e: Ageout AP 10.25.34.31-94:b4:0f:94:c2:01-NDHAM01AP261 Client Match
    Jul 18 07:46:52 :501000:  <DBUG> |AP NDHAM01AP261@10.25.34.31 stm|  Station 34:02:86:a6:bb:3e: Clearing state
    Jul 18 07:46:52 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 22
    Jul 18 07:46:52 :522036:  <INFO> |authmgr|  MAC=34:02:86:a6:bb:3e Station DN: BSSID=94:b4:0f:94:c2:01 ESSID=AirFlight VLAN=3000 AP-name=NDHAM01AP261
    Jul 18 07:46:52 :522234:  <DBUG> |authmgr|  Setting idle timer for user 34:02:86:a6:bb:3e to 300 seconds (idle timeout: 300 ageout: 0).
    Jul 18 07:46:52 :522152:  <DBUG> |authmgr|  station free: bssid=94:b4:0f:94:c2:01, @=0x0x16ca0f4.
    Jul 18 07:46:52 :501000:  <DBUG> |stm|  Station 34:02:86:a6:bb:3e: Clearing state
    ## auth to AP 262 (right side office)##
    Jul 18 07:46:57 :501093:  <NOTI> |AP NDHAM01AP262@10.25.34.30 stm|  Auth success: 34:02:86:a6:bb:3e: AP 10.25.34.30-94:b4:0f:94:38:b1-NDHAM01AP262
    Jul 18 07:46:57 :501095:  <NOTI> |AP NDHAM01AP262@10.25.34.30 stm|  Assoc request @ 07:46:57.254841: 34:02:86:a6:bb:3e (SN 309): AP 10.25.34.30-94:b4:0f:94:38:b1-NDHAM01AP262
    Jul 18 07:46:57 :501100:  <NOTI> |AP NDHAM01AP262@10.25.34.30 stm|  Assoc success @ 07:46:57.256046: 34:02:86:a6:bb:3e: AP 10.25.34.30-94:b4:0f:94:38:b1-NDHAM01AP262
    Jul 18 07:46:57 :501100:  <NOTI> |stm|  Assoc success @ 07:46:57.271437: 34:02:86:a6:bb:3e: AP 10.25.34.30-94:b4:0f:94:38:b1-NDHAM01AP262
    Can we overcome this from happening? I don't want to disable Client Match, since it's a good feature for roaming in other parts of the building.
  • 2.  RE: Client Match makes user briefly disconnect
    Posted Jul 18, 2016 10:34 AM
    Client match activates for three reasons:
    Client is too "sticky"
    Too many clients on an access point
    Client is dual band and ends up on the 2.4ghz band.
    You can minimize two out of the three by turning down the max tx power in the ARM profile.
    What is the max tx power in your ARM profile?
  • 3.  RE: Client Match makes user briefly disconnect
    Posted Jul 18, 2016 10:36 AM
    Hi CJ,
    I have current ARM profiles running on the office environment. one for A and one for G
    rf arm-profile "ARM_OPENOFFICE_A"
    no 80MHz-support
    max-tx-power 15
    min-tx-power 12
    ideal-coverage-index 6
    backoff-time 1800
    error-rate-wait-time 90
    cm-unst-ageout-intvl days 0 hours 4
    cm-band-g-max-signal 10
    cm-steer-timeout 3
    cm-max-steer-fails 5
    cm-lb-client-thresh 60
    rf arm-profile "ARM_OPENOFFICE_G"
    no 80MHz-support
    max-tx-power 9
    min-tx-power 6
    free-channel-index 40
    backoff-time 1800
    error-rate-threshold 70
    cm-steer-timeout 3
  • 4.  RE: Client Match makes user briefly disconnect
    Posted Jul 18, 2016 10:55 AM
    There are parameters that have been modified from the defaults, but nothing stands out a causing your issue specifically. On that specific client with the issue, what client match trigger happens most often?
  • 5.  RE: Client Match makes user briefly disconnect
    Posted Jul 18, 2016 11:08 AM
    Hi CJ,
    would following output answer your question? If not, please let me know which output you need.
    PS: the only time the user complaint about losing connection was around the 07:47 timestamp
    Jul 18 07:08:49 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 22
    Jul 18 07:20:03 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 81
    Jul 18 07:46:25 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 07:47:42 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 07:52:23 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 81
    Jul 18 08:13:05 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:25:36 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:27:04 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:27:47 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:28:19 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 22
    Jul 18 08:31:56 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:33:07 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:41:50 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:42:42 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:46:36 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 1
    Jul 18 08:57:29 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 1
    Jul 18 08:58:58 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:59:10 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:59:24 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 08:59:35 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 09:00:56 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 22
    Jul 18 09:01:26 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 22
    Jul 18 09:03:42 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 09:14:17 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 09:28:34 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 09:37:19 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:04:14 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:04:32 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 22
    Jul 18 10:22:08 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:22:19 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:22:22 :522289:  <DBUG> |authmgr|  Auth GSM : MAC_USER mu_delete publish for mac 34:02:86:a6:bb:3e bssid 94:b4:0f:94:d4:a1 vlan 3000 type 1 data-ready 0 deauth-reason 52
    Jul 18 10:22:22 :501106:  <NOTI> |stm|  Deauth to sta: 34:02:86:a6:bb:3e: Ageout AP 10.25.34.32-94:b4:0f:94:d4:a1-NDHAM01AP263 wifi_deauth_sta
    Jul 18 10:22:22 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 52
    Jul 18 10:22:24 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:22:25 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:22:26 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:22:29 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:23:00 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:23:59 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 0 deauth_reason 68
    Jul 18 10:40:47 :522296:  <DBUG> |authmgr|  Auth GSM : USER_STA delete event for user 34:02:86:a6:bb:3e age 1000 deauth_reason 56
  • 6.  RE: Client Match makes user briefly disconnect
    Posted Jul 18, 2016 11:16 AM
    Please try this command:
    show ap arm client-match history client-mac<client-mac>
  • 7.  RE: Client Match makes user briefly disconnect
    Posted Jul 18, 2016 11:18 AM
    (NDEMHAM01WD1WC01) #show ap arm client-match history client-mac 34:02:86:a6:bb:3e
    S: Source, T: Target, A: Actual
    BTM-ACC: 11v BTM Accept, BTM-REJ#: 11v-BTM Reject with reason #, BTM-TO: 11v-BTM Timeout, BTM-FA: 11v-BTM False Accept
    Unit of Roam Time: second
    Unit of Signal: dBm
    ARM Client match History
    Time of Change       Station            Reason      Status/Roam Time/Mode           Signal(S/T/A)  Band(S/T/A)   Radio Bssid(S/T/A)                                     AP Name(S/T/A)
    2016-07-18 10:04:32  34:02:86:a6:bb:3e  Band-steer  Success/0/Deauth                -40/-56/-56    2.4G/5G/5G    94:b4:0f:94:38:a0/94:b4:0f:94:38:b0/94:b4:0f:94:38:b0  NDHAM01AP262/NDHAM01AP262/NDHAM01AP262
    2016-07-18 09:01:29  34:02:86:a6:bb:3e  Band-steer  Acceptable/3/Deauth             -52/-59/-44    2.4G/5G/5G    94:b4:0f:94:38:a0/94:b4:0f:94:38:b0/94:b4:0f:94:c2:10  NDHAM01AP262/NDHAM01AP262/NDHAM01AP261
    2016-07-18 09:01:01  34:02:86:a6:bb:3e  Band-steer  Wrong-Radio/5/Deauth            -51/-60/-51    2.4G/5G/2.4G  94:b4:0f:94:38:a0/94:b4:0f:94:38:b0/94:b4:0f:94:38:a0  NDHAM01AP262/NDHAM01AP262/NDHAM01AP262
    2016-07-18 08:28:25  34:02:86:a6:bb:3e  Band-steer  Uncontrolled-Radio(I)/6/Deauth  -83/-72/-      2.4G/5G/5G    94:b4:0f:94:d4:a0/94:b4:0f:94:d4:b0/94:b4:0f:94:d7:70  NDHAM01AP263/NDHAM01AP263/NDHAM01AP264
    2016-07-18 07:46:57  34:02:86:a6:bb:3e  Band-steer  Wrong-Radio/5/Deauth            -39/-42/-58    2.4G/5G/5G    94:b4:0f:94:c2:00/94:b4:0f:94:c2:10/94:b4:0f:94:38:b0  NDHAM01AP261/NDHAM01AP261/NDHAM01AP262
  • 8.  RE: Client Match makes user briefly disconnect
    Posted Jul 18, 2016 11:17 PM
    If your clients are repeatedly being band steered, that means there is not enough separation between the 2.4ghz and the 5ghz.  The 5ghz should be stronger than the 2.4ghz so that the client does not keep going back...
  • 9.  RE: Client Match makes user briefly disconnect
    Posted Jul 20, 2016 05:33 AM
    Hi CJ,
    should I then play around with the min/max TX values of the ARM profile for 5ghz?
  • 10.  RE: Client Match makes user briefly disconnect
    Posted Jul 20, 2016 08:42 AM
    The arm profile min/max for 5ghz should be at least 3 higher than the 2.4ghz. 5ghz max should not be over 18, however. You might have to reduce the 2.4ghz to accomplish this.
  • 11.  RE: Client Match makes user briefly disconnect
    Posted Jul 25, 2016 10:05 AM
    For the moment I have raised the 5ghz Max to 18, without changing the 2,4 values.
    5:
    Max: 18
    Min: 12
    2,4
    Max: 9
    Min: 6
    with this the 5ghz will broadcast a bit stronger as before, and the client might stay on that band.
    Let me monitor the situation.
  • 12.  RE: Client Match makes user briefly disconnect
    Posted Jul 28, 2016 06:28 AM
    Hi CJ,
    still seeing the user Band-steer:
    2016-07-28 09:13:04  34:02:86:a6:bb:3e  Band-steer  Success/0/Deauth       -44/-54/-54    2.4G/5G/5G   94:b4:0f:94:c2:00/94:b4:0f:94:c2:10/94:b4:0f:94:c2:10  ND                                             HAM01AP261/NDHAM01AP261/NDHAM01AP261
    2016-07-28 08:51:59  34:02:86:a6:bb:3e  Band-steer  Success/1/Deauth       -40/-50/-50    2.4G/5G/5G   94:b4:0f:fe:bb:40/94:b4:0f:fe:bb:50/94:b4:0f:fe:bb:50  ND                                             HAM01AP277/NDHAM01AP277/NDHAM01AP277
    2016-07-27 15:09:23  34:02:86:a6:bb:3e  Band-steer  Success/1/Deauth       -52/-50/-50    2.4G/5G/5G   94:b4:0f:94:d7:60/94:b4:0f:94:d7:70/94:b4:0f:94:d7:70  ND                                             HAM01AP264/NDHAM01AP264/NDHAM01AP264
    2016-07-27 14:19:47  34:02:86:a6:bb:3e  Band-steer  Success/0/Deauth       -47/-46/-46    2.4G/5G/5G   94:b4:0f:94:d7:60/94:b4:0f:94:d7:70/94:b4:0f:94:d7:70  ND                                             HAM01AP264/NDHAM01AP264/NDHAM01AP264
    2016-07-27 11:03:54  34:02:86:a6:bb:3e  Band-steer  Success/5/Deauth       -36/-42/-42    2.4G/5G/5G   94:b4:0f:94:c2:00/94:b4:0f:94:c2:10/94:b4:0f:94:c2:10  ND                                             HAM01AP261/NDHAM01AP261/NDHAM01AP261
    but when checking the options in the VAP, I noticed that the Band-steering functionality was not enabled:
    Aruba is also saying not to combine Client Match with Band-steering:
    http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Content/ArubaFrameStyles/ARM/Band_Steering.htm
    any advice on this?
  • 13.  RE: Client Match makes user briefly disconnect
    Posted Jul 28, 2016 07:58 AM
    When ClientMatch is enabled, the band-steering settings are ignored.  ClientMatch is enabled by default so the Virtual AP bandsteering setting is ignored.
    There is nothing wrong with a client being band-steered successfully in principle.
