I'm trying to figure out what client-match settings I should tweak for optimal performance in a highly mobile environment like nurses in hospitals or orderpickers in huge warehouses.
Two timers confuse me a bit.
Client Match Sticky Client Check Interval has AP check every 3 seconds to see if it should boot of a sticky client right?
How does that work if the Client Match report interval where the APs send their beacon reports to the controller only happens once every 30 seconds?
Its possible for clients to fail this steering.. what precisely does that mean? If you deauth a client and then only accept its association on one target AP, how can it fail and still be connected?
