Client names not showing up on my Virtual Controller
  • 1.  Client names not showing up on my Virtual Controller
    Posted Sep 11, 2014 12:31 PM
    I am having a small issue with my production network. I am using 2 IAP-225's and have configured properly working wireless access, however, on my virtual controller, all my clients have a "--" as there name.  I also set up a demo lab within our private network with an IAP-105 and an IAP-115 and when clients connect, their device name shows up. Please let me know if anyone has a solution or has encountered something similar. I've included a screen shot. Thanks
  • 2.  RE: Client names not showing up on my Virtual Controller
    Posted Oct 30, 2014 05:15 PM
    Has anyone come up with an answer for this one?
  • 3.  RE: Client names not showing up on my Virtual Controller
    Posted Oct 30, 2014 05:57 PM
    Yes! I forgot to answer the questions when I figured out my problem. I updated to the newest AOS version and it solved the issue. HTH
    Best Regards,
    Sean
  • 4.  RE: Client names not showing up on my Virtual Controller
    Posted Oct 30, 2014 06:16 PM
    Thanks, I thought I had already done this but hadnt.  Solved the issue.
    Thanks again
